Lemon?
Lemon?
2007 with 3,300 miles. Truck pulls to the left significantly while braking from 50mph on. I have had this truck to two different dealers 6 times. They are stumped. Two sets of brake pads and a tire rotation. Two ride-a-longs with the service manager who admits the truck pulls and has a problem, but can not offer any advice on how to fix it. What can I do with this truck? Does this qualify as a lemon?
Im in CA. 4 attempts here. I like the truck and am all about giving chances, but I am at my boiling point.
Originally Posted by poppie
try a 3'ed dealer and have them also change out the rotor's with the pad's,might be possible the one that pull's was not heat treated right and is softer making it grab more than the other side,a long shot but possible.
Originally Posted by Baumbach
I just picked up a 2008 Expedition on 07-11-07 and have less then 2k miles on it and also notice an intermittent pull to the left from the brakes while braking from higher speeds, it gets worse if you are pulling a trailer.
After you drive a bit check the wheel temperature with your hand and see if the rear left is not hotter than the rest. It was in my case.
