Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 07-30-2007, 12:02 PM
berry1234's Avatar
berry1234 berry1234 is offline
Garage is empty, add now
berry1234 is gaining momentum as a positive member of FTE.
Lemon?
2007 with 3,300 miles. Truck pulls to the left significantly while braking from 50mph on. I have had this truck to two different dealers 6 times. They are stumped. Two sets of brake pads and a tire rotation. Two ride-a-longs with the service manager who admits the truck pulls and has a problem, but can not offer any advice on how to fix it. What can I do with this truck? Does this qualify as a lemon?
  #2 (permalink)
Old 07-30-2007, 01:00 PM
Triboy's Avatar
Triboy Triboy is offline
Triboy is starting off with a positive reputation.
Quote:
I think it depends on what state you live in. In my state the dealer has 3 chances to repair the issues before it is eligible to be a lemon.
  #3 (permalink)
Old 07-30-2007, 01:29 PM
berry1234's Avatar
Quote:
Im in CA. 4 attempts here. I like the truck and am all about giving chances, but I am at my boiling point.
  #4 (permalink)
Old 07-30-2007, 04:07 PM
poppie poppie is offline
poppie is starting off with a positive reputation.
try a 3'ed dealer and have them also change out the rotor's with the pad's,might be possible the one that pull's was not heat treated right and is softer making it grab more than the other side,a long shot but possible.
  #5 (permalink)
Old 07-30-2007, 04:09 PM
berry1234's Avatar
Quote:
There is no 3rd dealer within 30 miles of me. And telling them what to replace is pretty much worthless.
  #6 (permalink)
Baumbach Baumbach is offline
Baumbach is starting off with a positive reputation.
I just picked up a 2008 Expedition on 07-11-07 and have less then 2k miles on it and also notice an intermittent pull to the left from the brakes while braking from higher speeds, it gets worse if you are pulling a trailer.
  #7 (permalink)
Old 07-30-2007, 04:32 PM
berry1234's Avatar
Quote:
I feel for you. I have my 5th appointment tomorrow. I spoke to another service manager and he has not heard of pulling from the newer Expeditions. Hopefully they can figure something out. If they do I will of course post what was fixed.
After you drive a bit check the wheel temperature with your hand and see if the rear left is not hotter than the rest. It was in my case.
  #8 (permalink)
Old 08-08-2007, 09:32 PM
gotfu gotfu is offline
gotfu is starting off with a positive reputation.
caliper sticking or not getting enough fluid to the right side?
__________________
2004 f350 cc lb 4x4 4"turbo back,autometer gauges, 12000lb fiver
  #9 (permalink)
Old 08-09-2007, 10:53 AM
berry1234's Avatar
Quote:
How is this tested?
  #10 (permalink)
Old 08-10-2007, 07:07 AM
bcjim bcjim is offline
bcjim is starting off with a positive reputation.
SOunds like they arent trying very hard to find the problem, it could only be so many things.. Regardless, just keep leaving it there until it is fixed or becomes lemon eligible.
__________________
98 Ranger SC 4X4
03 Explorer 4x4
  #11 (permalink)
Old 08-10-2007, 08:32 AM
carbonmetallic carbonmetallic is offline
carbonmetallic is starting off with a positive reputation.
are any of you having transmission shifting problems?
  #12 (permalink)
Old 08-10-2007, 10:57 AM
berry1234's Avatar
When I take off from a rolling start it seems to start off in 2nd, then shifts back to first.
Tags
2010, braking, ford, lemon, lemons, pulls, truck, trucks, whichfordtruckswerelemons, worst
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
