Brake pedal creeks?
Brake pedal creeks?
Hey all
Couple days ago, my brake pedal started creeking/squeaking. It does that when I apply brakes and when it comes back up when I let it go. By the sound, it definetely comes from the pedal itself inside the cabin.
How do I fix it? It gets very annoying
Thanks a lot again. It seems like recently my truck needs a lot of attention
noise
jeepers you guys---stop talking about this or it will happen to me!
I did have a activation rod on a Cutlas many yrs ago that was binding up and making noise and had to replace the booster and Master C. It was a much bigger job than I anticipated---but got it done---
I sure don't expect to have to do it before 100K--knock on sheet metal mine is OK for now----
Originally Posted by hkiefus
Me too, me too, me too! But, the sound makes just the PERFECT turkey call. I'm going to want until after next spring's gobbler season before I fix mine.
HAA!
(Just picturing me and a couple buds all camoed out, tapping the brake pedal on the truck with shotguns at the ready...) HAAAA!
Best,
--41-Duck
I took the car to the mechanic to look at the brake pedal. He discovered that the adjustable pedals do not work anymore. The pedals are stuck in one position and do not move when using the up/down switch on the dashboard. He said that it might be the cause of the problem. What do you all think?
How much would it cost to replace the adjustable pedal motor and switch? (Even if that is not the cause of the creeking noise, I would still like to get my adjustable pedals working again)
Thanks a lot in advance
i have this problem also?? my adjustable pedal still works but the sponge sound is anoying! its mostly a sound, doubt its the booster, the trucks stops fine.. anyone figure this out yet?? to my it seems like the pedal system itself?? im going to try to greese it up and see what happens,, also it seems to be worse at times and better at others.. very odd... anyone???
Great example. I've been trying to find the words to describe this annoying noise. I've done searches on the term "squeaking pedal", "noisy pedal", "creaking pedal".....never thought of "turkey calling pedal"!
Want to bump this one along. Has anyone got any resolution to the problem? My pedal has been making this horrible creaking noise for the past year. I tried spraying Kroil (the same magical stuff used in removing spark plugs from the heads) but it isn't hitting the right spot.
