Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Virginia Chapter Join Chapter, Leader: archtaan
  #1 (permalink)
Old 07-29-2007, 02:15 PM
JWILL460 JWILL460 is offline
Garage is empty, add now
JWILL460 is starting off with a positive reputation.
Brake booster?
So I just moved to Northern Virginia from Iowa,driving in on Fri-Sat. I drove my 88 K5 Blazer out here and it actually did great on fuel consumption and cruising speed however since Ive arrived my breaking power has gone down about 50%. It had new rotors and pads on the front just before I left Iowa and now it has a very spongey pedel feel and takes forever to stop. Could this be a brake booster? Im not sure how Im going to fix any of this as I cant work on my truck here at the house because of the home owners association. Does this problem sound like a brake booster to anyone else? Fluid level in the master cyl is full as Ive checked in multiple times. I start work on Monday and hope to get this figured out tonight.
Jwill.
  #2 (permalink)
Old 07-30-2007, 02:56 PM
kjett's Avatar
kjett kjett is offline
kjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to behold
Well, since you are on a Ford site, I have to be the 1st to say that the problem with the blazer is the bow tie on the front!!
Now that the ice is broken, whe you put new pads on, did you change the fluid or open the bleeders any? Might have an air bubble in the line. Try to open all for bleeders and gravity bleed the system and also check for any loose fittings as this will allow the air to be sucked back into the system. If that doesn't fix it, then you may have either a bad booster or master cylinder. Either way, if it's the booster, might as well change the MC while you are at it.
__________________
Karl
Quote:
Originally Posted by alpha/omega View Post
I dont think Im ever drinking again....
1995 F-150
Ranger Mud Truck
Tags
77, booster, brake, bronco, rere
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
