1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
brakes
Old 10-17-2016, 11:44 AM
hoso50's Avatar
hoso50
hoso50 is offline
brakes
have 99 f350, super duty 7.3 dually. Am going to need extra heavy duty brake rotors and pads. any suggestions.
Old 10-19-2016, 07:12 AM
The Bone's Avatar
The Bone
The Bone is offline
You can't have to much brakes. Get the best brakes you can afford. Not the racing ones just the truck ones.
Old 10-19-2016, 08:47 AM
agpopp's Avatar
agpopp
agpopp is offline
I've had good luck with the Motorcraft severe duty pads and use bendix (wearever) rotors from advance since the pads will prob eat them up. Got the pads on Amazon
Old 10-20-2016, 10:12 AM
Tractionless's Avatar
Tractionless
Tractionless is offline
Raybestos Advanced Technology Metallics were night and day over OE in my '06 F-250 on OE rotors. Just threw a set in the rears on my '08 F350. Great price and much lower dust as well.
Old 10-20-2016, 12:47 PM
SnowPlowDriver's Avatar
SnowPlowDriver
SnowPlowDriver is offline
First time I removed that caliper bracket on my 2011 I needed a pipe and breaker bar. They are assembled with loctite.
Old 10-20-2016, 05:40 PM
4x4pwr's Avatar
4x4pwr
4x4pwr is offline
I am running powerstop rotors with their pad kit from amazon. Zero complaints.
https://www.amazon.com/Power-Stop-K1...+and+pads+f250
Old 10-20-2016, 06:05 PM
hoss66's Avatar
hoss66
hoss66 is offline
Check out the power stop truck and tow brake kit, they make a set with calipers too if you need or want to replace those
Old 10-20-2016, 07:10 PM
Tractionless
Air or expensive battery powered impact will do the trick as well.
I got a bit of advice about the calipers on Ford trucks a few years ago when doing front pads. The Ford certified master tech. said replace or rebuild all the calipers at the same time. I laughed, cleaned the caliper pistons as I do on all my vehicles and pushed them back in before installing the pads. After bleeding 1 of the calipers was locked open so I replaced it. Fifty miles later, while towing on the highway the other front seized and got so hot it blued the rotor. Lesson learned.
I just replaced pads AND rotors on the rear of my '08 for peace of mind. Come to find out the calipers fail many an owner. Both of my '06 rear calipers locked up on the road a year after it's purchase and not because of a pad change.
hoso50
11-02-2016 11:48 PM
pin8246
05-12-2015 09:40 AM
78sForever
02-20-2015 06:29 AM
Quick Reply: brakes
