HELP!!! Ford Tow Command "TBC Fault" message - Page 3 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #31
Old 07-10-2010, 11:02 AM
Heavy Duty f250 Heavy Duty f250 is offline
Heavy Duty f250 is starting off with a positive reputation.
I had the same problem with my 2005 F250. After 8 trys at the dealer and and them replacing alot of parts they discovered the fuse box was bad. Is your truck surging at low speeds and does the cruise control and the tow haul mode have a mind of their own?
  #32
Old 07-10-2010, 11:09 AM
allingeneral's Avatar
allingeneral allingeneral is offline
allingeneral is gaining momentum as a positive member of FTE.
Quote:
I don't seem to be experiencing any problems other than the fault code.
  #33
Old 07-14-2010, 10:57 PM
mrw1 mrw1 is offline
mrw1 is starting off with a positive reputation.
Trailer brake command problems
I have a 2006 f250 diesel and i too am getting the trailer brake controller fault. THe fault comes on everytime the truck is started but can be reset. It will also come on if I manually operate the brake controller. The controller is operating properly and the trailer brakes work fine. I get the fault even when I do not have a trailer hooked up. I have checked the connections at the 7 pin connector at both the trailer side and the harness side and there is no sign of moisture or corrosion. I do not see the connection at the firewall that I have read about in other posts. I am guessing that the module needs to be replaced but I was looking for a way to test it. The dealer quoted me $505.67 which is full retail price. If it needs to be replaced I want to find a dealer that is more reasonable. Any suggestions?
  #34
Old 09-23-2010, 11:59 AM
airpilikia's Avatar
airpilikia airpilikia is offline
airpilikia is starting off with a positive reputation.
Have this happening to my 06 F250 6.0 also. Just took it to the dealer and they told me it was the controller. Told them I would fix it myself. I am going to call some junk yards and try to find one. I will post back the results.
  #35
Old 09-23-2010, 02:28 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Get a quote from ED...FTE sponsor for Ford parts......www.partsguyed.com
  #36
Old 09-23-2010, 03:15 PM
donovan donovan is offline
donovan has a great reputation on FTE.donovan has a great reputation on FTE.donovan has a great reputation on FTE.donovan has a great reputation on FTE.donovan has a great reputation on FTE.
TBC Fault
What the dealer did in order to fix my 05 tbc fault
Drew Ford
1 Greased the connector on the rear of the truck
2 Replaced the gauge cluster, they said it had a bad diode
3 Replaced the master cylinder
4 Cleared the code right be for a long haul trip, they said it was left over because they did not clear the computer.
Limp Mode activated 150 miles from home and I started to lose break pressure on the trip, I went to Galpin Ford.
1. Diagnosed the entire truck and found Master Cylinder (Bad install job by Drew Ford) and bad turbo
2. Redid the repair of the master cylinder.
3. Replaced the Turbo(I did not even know it was bad)
4. Did something with the wiring on the firewall.
4. Sold me a new truck so I could finish the family vacation
5. Return the 05 in two weeks. Truck was stronger then it ever was.
Where you take your truck makes a HUGE difference in the quality of the repair.
  #37
Old 09-23-2010, 03:50 PM
So, what was the problem? Wiring in the firewall?
I initially thought that my Tow Controller was faulty, but I'm having second thoughts now. I've also heard that there's a speed sensor in the rear end that can cause this problem if it's faulty.
I sure would like to correct the issue without spending several hundred bucks at the Ford dealership.
  #38
Old 09-23-2010, 04:08 PM
TBC fault
Galpin did not want to bash the other dealer but It was the change of connectors on the firewall. I can't even see where they change the connectors.
Donovan
  #39
Old 09-23-2010, 06:32 PM
sandmanf250 sandmanf250 is offline
sandmanf250 is gaining momentum as a positive member of FTE.
how much weight are we talking about ?
  #40
Old 09-23-2010, 07:23 PM
airpilikia's Avatar
If I buy a new controller will I still have to go to the dealer to get the fault cleared?
  #41
Old 09-23-2010, 07:26 PM
airpilikia's Avatar
Or just disconnect the batteries?
  #42
Old 09-24-2010, 10:46 AM
airpilikia's Avatar
Any help here bump!
  #43
Old 09-24-2010, 11:09 AM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
I think you aren't getting a response because nobody here has ever seen a TBC Fault message throw a code... or even "stick".
At the most, to reset the TBC and remove the "fault" you just have to restart the vehicle.
  #44
Old 11-03-2010, 07:48 PM
06 F-350 King Ranch 06 F-350 King Ranch is offline
06 F-350 King Ranch is starting off with a positive reputation.
same thing
I have the same problem with the TBC fault code coming up everytime I start the truck. If someone can tell me what to change so I can fix it please send a pm.
Thanks
Mark
  #45
Old 11-04-2010, 08:27 AM
I get the TBC fault every time I start my truck as well ('06 F250 diesel). It's annoying. I have found that I can press the Odometer Reset switch once to clear it from the display, and it doesn't come back until the next time I start it up.
It also seems that the brake controller has stopped working altogether. There is no display on the TBC, even when I try to manually apply. This is without anything hooked to the system. I've never even used the brake controller!
TBC Fault Code help 2007 F250 SD Powerstroke blind180 1999 to 2016 Super Duty 13 11-14-2016 10:34 PM
TBC fault emmagator 6.0L Power Stroke Diesel 7 05-23-2013 03:02 PM
TBC Fault mnmwhit 6.0L Power Stroke Diesel 2 12-16-2012 01:56 PM
TBC Fault Code need help mrw1 1999 to 2016 Super Duty 1 01-01-2012 06:11 PM
Tow Command TBC Fault Gunner15a 1999 to 2016 Super Duty 6 05-30-2006 10:31 AM
Tags
07, 2005, brake, code, default, duty, f250, f350, fault, ford, problems, replacement, super, tbc, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
