You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Well I have a bad driveshaft...or I was told. I took it to Sadler Powertrain. They said it was junk; splines bad h-yoke, cv head: which i was pretty sure was bad before i took it there, and the u-joints: which surprised me becuase i just had put them in the day before. Now i am in need of some info of a place to take it to, to be rebuilt or a place to get a new shaft. Any info is appreciated.
Thanks
Steinbronn
Also, just bought a highboy and was wondering if the shaft is the same as the one i am needing. My truck is a '77 F150 shortbed 4x4 (needs new rear driveshaft), highboy is a 1975 longbed? Don't know just wondering
The highboy also has a divorced case, so it will be different. Sadler should be able to get the parts, if they can be had new.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
Thanks
Steinbronn
Short bed trucks have a one piece driveshaft. Trucks with long beds use a two piece driveshaft.
Officially: Only the front half of a two piece driveshaft is refered to as such. The rear half is called a coupling shaft.
When searching for a new driveshaft, in addition to listing the wheelbase and whether the truck is either 2 or 4WD, the type of transmission must be listed.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
thanks for the help guys....i appreciate it. the only reason i brought up the highboy idea is that i was under it the other day and front driveshaft looked similar to the one i have in my 77.
