Help Need Quick Help
yes, thanks, is the eye bolt on the spare tire carrier on a 95 f150 2 wheel drive supposed to be tighetend, i just bought this truck and am putting the spare back on, there is no center retainer or anything because of the rear gas tank, and i cant get the eye bolt to spin inside the j nut to hold the tire tight to the tank. i sprayed it with wd40 and some aero kroil, but to no avail, i really dont want to put heat to it, because of the close proximity to the rear tank.
thanks all
thanks all
A few years earlier the spare sat in a cradle which is lifted up to the eyebolt. There is a slot in the cradle the eyebolt goes through and then you tighten it snug. The eyebolt itsle doesnt hold the tire, it holds the cradle which holds the tire. Im not sure on the 95, but thought Id mention it just in case its simliar. Also make sure the eyebolt is sitting on the raised notch in the cradles slot, not in the slot it passes through.
B
B
SuperDuty93
16
06-22-2011 08:44 AM
leonharu
29
01-23-2007 05:34 PM
petersons
02-10-2003 03:42 AM
