Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-26-2007, 11:39 PM
Bones_Big_F250 is starting off with a positive reputation.
360 big block???
Hey everyone, i got a 73 F250 i was told it had a 360ci big block. i really don't know anything about it. just wondering what you guys could tell me about it? also it's a 4x4 highboy, any knowledge bout the transfer case and gears would help out alot too.
Thanks Bone
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-27-2007, 12:18 AM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Quote:
Thanks Bone
Your 360 is of the FE engine family. Lots of info in the engine threads. In the day, it was derided as a gutless gashog, having replaced the 352 which, while thirsty as well, somehow seemed like a mover to some folks. (perhaps it was those 4bbl twice piped units in station wagons, which did run pretty good...) Alas, the poor 360 with low compression and a 2bbl and a smallish single exhaust used as much gas as the more energetic 390, but delivered not the snap of the bigger unit.
As for TC, not sure. Rear gears, you should have a tag on one of the bolts holding the cover on the diff. Look for a string of letters and numbers and post it here. (4L10 or 4L56 in the string would indicate 4.10 or 4.56 with limited slip) See the clutch/trans etc forums as well. Also, your vin will have an axle code in it. A couple (one in particular) members can decode those numbers. (numberdummy for sure)
This truck is all in one piece and runs and the 4x4 works, etc?
  #3 (permalink)
Old 07-27-2007, 12:45 AM
Yeah the truck is one piece, i just rebuilt the engine with all new gaskets and full tune up before i deployed. when i get back from iraq i'm gonna start the frame off restoration. just wandering if i should keep the 360 or lose it. i was thinking of swapping in a 351ci, thoughts on this?
  #4 (permalink)
Old 07-27-2007, 01:43 AM
FordTrucksKickGM is starting off with a positive reputation.
Id check with the guys in the FE forum on the engine stuff. Ive heard stories of guys swapping perfectly good 390s for 360s. I think the cylinder walls are thicker or the blocks are some how stronger than a 390 so theres more potential for a buildup. As a side note I dont think 390s were offered in a 4x4. Either way I woundnt swap a 360 for any of the 351s. For the transfer case it depends if you have a full time or part time one.
  #5 (permalink)
Old 07-27-2007, 09:23 AM
tatonka04 is starting off with a positive reputation.
Hey Bones, glad to hear about the resto project. I just retired and am currently restoring a 75 F250 4x4 with the 360. Must be an Army thing. Anyhow, Wikipedia has some good info on them under the search Ford FE engine. It has the whole history of them. Also, this site is awesome for doing a project. These guys definitely know their stuff. I haven't got to the engine yet, (I'm still sanding and painting the frame and fixing 32 years of use and abuse), but I was planning on keeping the 360 and making it into a 390. I'm not a Ford guru, but from what I've read, they are pretty decent engines.
  #6 (permalink)
Old 07-27-2007, 06:11 PM
Action4478 is gaining momentum as a positive member of FTE.Action4478 is gaining momentum as a positive member of FTE.
I have a 63 ( Iwas told)390 in my 76,, bolted right in ,, seemed to be alot better on the bottom,of course , It may have been the fresh30 over bore......(all in my head)....
  #7 (permalink)
Old 07-27-2007, 06:54 PM
76supercab2's Avatar
76supercab2 has a good reputation on FTE.76supercab2 has a good reputation on FTE.76supercab2 has a good reputation on FTE.
390s and 360s will swap between each other quite easily (as will any other FE). To change to another engine family (351C) would require quite a bit of spare parts (engine mounts, mount towers, bellhousing, accessories etc).
'Small block'/'Big block' is a chevy term that means very little (absolutely nothing) when talking about Fords. In chevy-land you could ask for a "small block oil pump" and get the right part. If you want an oil pump for a 351 Ford, there's the 351W, 351C, and 351M. And very few (no internal) parts swap between engine families.
  #8 (permalink)
Old 07-27-2007, 07:24 PM
MintFord's Avatar
MintFord is starting off with a positive reputation.
I really like the 360 in my '77 F250. Was a 400 truck but someone put a '73 360/ 4spd in there at some point. Its not super fast, but then again its got the stock 2bbl and single exhaust. Got loads of low-end torque though and it warms up quickly and runs awesome even in winter weather.
__________________
Dan
ASE Certified Master Tech
1970 Chrysler Newport 383 / 727
1971 Chrysler Newport 383 / 727
1984 Mercury fox Marquis 5.0 HO EFI / C5
1990 F150 XLT Lariat 4x4 300 I6 / E4OD / 3.55
1992 Lincoln Towncar Executive
1995 Dodge Intrepid 3.3L
  #9 (permalink)
Old 07-27-2007, 11:59 PM
condolan is starting off with a positive reputation.
Yes, research on the FE engine's forum will provide tons of neat information for you.
Although I have no personal experience, I think those older F250's were well-known for being pretty tough pickups.
__________________
-"$lick"
1984 Ford F150 4x4 (300 Six, 4-speed)-daily driver
1974 Ford F100 4x4 (360 V8/C6)-burnt up
1979 Toyota 4x4 pickup-rusting away
1986 Oldsmobile Cutlass Supreme-a 350 V8 is being prepped right now
If you don't like the weather in Montana, wait 5 minutes and it'll change.
  #10 (permalink)
Old 07-28-2007, 12:53 AM
i've been reading alot about them and think i'm just going to go with a 406 when i start the frame off. theres so many different opinions on here though, anyone have a real plan and parts list for one? i want something with some power that picks up pretty good with decent torque. it's gonna be a daily driver that i can just go romp around in occasionally. any help??
  #11 (permalink)
Old 07-28-2007, 01:41 AM
Well, my truck is still stock. But here's what I want to do to it some day, no specifics though. Just to give you some ideas:
-360 V8
-4 barrel carb/matching intake manifold
-daily driver camshaft with some power
-390 crank and rods/360 pistons
-oil modification that everybody talks about for the FE engines
-dual exhaust with headers
-C6 tranny that works!
-31 inch All-Terrains or Mud-Terrains
-9 inch rear packing a Detroit TrueTrac and 3.73 gears
Like I said, I haven't done any of those things to my truck yet, but I personally think that would be a pretty kickin' pickup truck right there.
__________________
-"$lick"
  #12 (permalink)
Old 07-28-2007, 04:54 PM
i thought the 360 pistons with the 390 crank would hit the heads on tdc?
  #13 (permalink)
Old 07-28-2007, 05:47 PM
Not from what I've researched. Now I could be wrong...but the best move for a 360 engine, when using parts from a 390, is to use the 390 crank and rods, but use the 360 pistons. Those pistons create more compression than the 390 pistons...but not so much that they kiss the valves on a stock cylinder head. But don't use the 390 crank with the 360 rods-that will create too much stroke. And the 360 rods are too long to be as strong as the 390 rods.
The best move is to use aftermarket 390 pistons...but those are pretty pricey. But, like many other things, you get what you paid for. And I imagine a good set of aftermarket 390 pistons would easily outperform factory 360 pistons.
But if you're building on a budget, then it's best to use the 360 pistons-considering they are still good.
This topic should be in the FE engines forum, but seeing as how it kinda' concerns the whole truck, I guess it's okay.
__________________
-"$lick"
  #14 (permalink)
Old 07-28-2007, 06:36 PM
fellro86's Avatar
Iowa Chapter lead
fellro86 has a great reputation on FTE.fellro86 has a great reputation on FTE.fellro86 has a great reputation on FTE.fellro86 has a great reputation on FTE.
The block is common between the 360 and the 390, the crank and rods are the only difference. Torque isn't a problem for a 390, haven't run a 360 yet, but the 390 I had initially in my 75 was pretty good runner, at least until it pitched a rod, due to antifreeze getting into the oil through the intake gasket, from the intake bolts not being tight from the PO swapping it.... Make sure to have the valve seats replaced if not already done, or you have to be careful to add something to lube the valves, unleaded fuel will ruin the heads, the FE motors were never factory built for unleaded.
Built right, a 360 or 390 should be a good thing. I have never heard anyone replacing 390's for 360's though, always the other way around, or converting. Main thing I ever heard was the 360 was a gutless gas hog, while the 390 has plenty of power, but still a gas hog. I got around 8 usually, with 4.10 axles.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, 47RH auto with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed
Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
  #15 (permalink)
Old 06-28-2008, 01:32 PM
shelbysf150 is starting off with a positive reputation.
i have a 76 4x4 with a 360 4 speed and it has no problem pushing pulling or lighting up the 32 inch tires best running ford ive ever owned and the only thing done ti it is coil and dual glasspacks.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
