Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
- Air Intake Modifications
Overview of popular modifications to customize your truck
7.3 IDI Mods
7.3 IDI Mods
I recently bought a 1993 Ford F250 and right now its completely stock but i was hoping to do a few mods like intake and exhaust and maybe even a turbo. but i cant find any kits for my truck. all the exhaust or intake kits i find are for 1994 and newer Fords. I was just wondering what mods you guys have done to your 7.3 IDI trucks...it doesnt necessarly have to be exhaust or intake. Im just looking for things i can do to my truck. Thanks
Pictures would be awesome!
netmaker
From the top;
- cold air intake. Make your own if you cannot buy and some 4" hot air pipe elbows and pipe will work wonders when extended to front on engine bay. Should cost about $50.00
- have your local exhaust dealer fit a twin 3" system and straight thru muffers from stock manifiolds. Should cost about $300
- add an electric fuel pump and raycor filter to fuel line system so you have the standard mechanical pump plus an electric pump delivering adequate fuel supply to injector pump. Cost about $50
- New paper air filter. Should cost about $65
- remove and close off fuel return line from standard fuel filter for better starting. A plug can be purchased to fit fuel line return orifice in filter housing. Should cost about $2.50
- Now you will flow air through the engine and match that increased flow to a adequate fuel supply from the dual pumps.
- Use a cetane fuel booster and injector pump lubricator like Powerkleen at 1 ozs per gallon
- Turn up the injector pump screw by about an eight of a turn and you will have the best performance that you can get from the lowest dollar.
- These engines were strangled for air when they were released and just by providing adequate air flow and fuel you will gain about 20 to 25 hp and if the engine is in reasonable condition you should be able to use that increase in power..
I'm about 1.5 months ahead of you.
Hypermax exhaust, about 300 shipped, very easy to hook up. http://www.gohypermax.com/Catalog.as...7-2376eff8edb1
Made for '93 specifically. That's the only money I've spent.
Look at http://www.members.shaw.ca/k2pilot/ it's a great site with pictures and pretty detailed instructions. I modded my intake almost exactly like that. I'm going to go to a junk yard soon and look for another air cleaner assembly to make mine a dual snorkle.
Next upgrade would be an EGT, then I'll look at turning up the injector. I don't think I'm going to get a turbo. This is just a "Tweener" truck for me and I can't see spending 2K for a turbo if I'm only going to keep it for a couple years. However I'm on the lookout for an inexpensive setup, just have to see what turns up.
Good luck and let us know what you do.
Banks sells a full turbo and exhaust kit for the 93.
I have a 1993 Ford F-350 with the Banks Sidewinder kit and love it. It includes everything needed to install the turbo and a complete upgraded exhaust system. Here is a link to their page:
http://store.bankspower.com/Categori...9-23fed85aa9fb
Have fun!
Have fun!
The following users liked this post:
I took the condenser from my a/c out to get it through. I'll never get all the leaks sealed again anyways. i havent gotten around to running a pipe all the way to the front of the truck yet. Sounds pretty good now and i have noticed i lost all the black smoke i used to have stock. Not sure but it seems to have a bit more jam.
More air in = more burned fuel = more 'Jam'
Thanks for the info
I have thought about running 2 intakes right out the side of the fender with either a grille (like the 08's) or scoop on each.
Netmaker ... I am currious about the 2 fuel pumps and blocking off that return line . How will this help ? The original setup should be able to deliver more than enough fuel .
I also noticed you left out advancing the timing on the ip . Other than that I understand & run the other mods .
1957f100 ... You may also consider headers if you don't want a turbo . I honestly believe mine added power. It's hard to say which added the most power , but it sure runs better . Mine is pretty spunky off the line & I am way under geared .
Originally Posted by netmaker
From the top;
Thanks!
--Finn John (90 F250 XLT/L StdCab 4x4, 4:10s, 5-spd, stock IDI 444 Int'l)
I will try to put up pics of these mods.
4 inch exhaust, just ordered parts for a ps and it fit right in the chassis.
ATS turbo
ps intercooler, ,04 6 liter, too big but works well. 13 psi 1k on the pyro.
Pump turned up almost to far.
bb injector bodies with e tips , pressure set to 1900 psi
Pics are too big. I am going to do a build site sometime with lots of truck resurection pics.
ATS turbo
