1994 F250 leaning tires - Ford Truck Enthusiasts Forums
Old 07-26-2007, 02:33 PM
renegd65 renegd65 is offline
renegd65 is starting off with a positive reputation.
Thumbs down 1994 F250 leaning tires
I have a 94 f250 with the twin i beam front end. It has the infamous sagging front end problem in which my tires are leaning in on both sides. In all honesty it was never that bad. About a year ago I put a 3" suspension lift on it. The lift came with the new frnt springs, pitman arm, ibeam drop brackets, and the blocks for the rear springs. Ever since I put the lift on it my tires have been leaning much worse. Since then I put new ball joints on it and then took it to my buddies shop to have an aligment put on it. He said the camber adjustment was adjusted all the way out, and that there was nothing he could do. Somebody told me that if you can drill a hole higher in the dropbracket and raise the arms up that it may correct the tire problem. Im just looking for a solution because Im wearing my tires out relatively quickly. If anybody has a solution I would really appreciate it!
Thanks,
Jon
Old 10-01-2009, 12:53 PM
btbet329 btbet329 is offline
btbet329 is starting off with a positive reputation.
I am having a very similar problem and would love any advice you guys would have.
Old 10-01-2009, 01:10 PM
jimjoebob99 jimjoebob99 is offline
jimjoebob99 is gaining momentum as a positive member of FTE.
Same here. This seems pretty common. lol.
Old 10-01-2009, 10:27 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
On a stock truck tires leaning in at the top simply means the springs are sacked so the fix is easy... get new springs. But since you have a lift your springs are not stock so you will either have to get a custom set of higher rate springs or modify the lift by install shims under the springs you have or raise the arms to correct the front end geometry. This applies to coil spring front ends only. If the truck has a leaf front end then you could simply add a leaf to increase the overall spring rate.
Old 10-01-2009, 10:29 PM
Chevy 6.2D's Avatar
Chevy 6.2D Chevy 6.2D is offline
Chevy 6.2D is starting off with a positive reputation.
You might also check the balljoints. I know you replaced them but maybe the lift caused them to wear out prematurely?
Front tire leaning out green_95 1994.5 - 1997 7.3L Power Stroke Diesel 8 09-11-2016 12:18 PM
lifted 2000 f150 with bad lean to driver side cglow1 1997 - 2003 F150 2 07-22-2016 09:39 AM
99 f250 8" lift: wanting reduce height with out changing lift Cheeva316 1999 to 2016 Super Duty 23 06-25-2014 10:56 AM
help with new leaf springs RRranch 1994.5 - 1997 7.3L Power Stroke Diesel 12 10-23-2011 04:39 PM
Front End Sagging/leaning Tires? renegd65 Brakes, Steering, Suspension, Tires, & Wheels 2 08-01-2007 11:42 AM
Tags
4x4, 94, beam, end, f150, f250, front, inwards, leaning, leans, outward, tire, tires, top, twin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
