sodium filled valves
The 428 had several different heads, three important things are:
valve size, exhaust bolt pattern, and port size. The chamber can be important for proper CR as well. The 428CJ heads have the bigger valves and larger runners. The standard 428 heads are the same as the 390 heads (C7AE-A, C8AE-H). Sodium valves are for handling heat and are not needed, but might be good to keep if in good condition.
The standard heads for the 390/390GT/428 are good up to 425HP and work well for street and mild perf use. The 428CJ heads with larger valves have a slower Air fuel charge and better for upper RPM. The standard heads work very well with a little port work and a duel pattern cam.
For a truck, the C7AE-A works very well and the C8AE-H will work well with proper piston match.
What's the casting numbers? and what is the application(RPM range, intake, carb, cam...)?
Just thought I'd mention that the sodium-filled valves in those heads are known for breakage. Not that they are bad, just that they have a history...
If your knuckles ain't bleeding you did something wrong.
'72 F-250 "Hi-Boy" 4x4, Dana 60/HD44, FE390 @ 400hp(purt near!), 4-speed, custom suspension w 4" lift, black on black.
We have three large Hysters. They are 22,500 lb lifts. The
two older ones have 350 Chevy motors, 4 bolt main, forged pistons
roller timing chain and the heads with sodium valves. The
newer Hyster has a big block chevy, I think it's a 366. They all have allison manually shifted three speed planetary transmissions. We have a yale with a Chrysler v6, and we
rented a lift one time that had a slant 6. Sorry to say, the
only Ford motor I've seen was in a tennant sweeper, a 1.6 liter
four cylinder.
four cylinder.
Rsmith2203
12-10-2016 05:43 PM
Rsmith2203
12-10-2016 12:45 AM
Nathan511
12-08-2016 11:09 PM
