A 302 bored .30 over = what? - Ford Truck Enthusiasts Forums
Old 07-26-2007, 10:23 AM
78Explorer 78Explorer is offline
78Explorer has a very good reputation on FTE.78Explorer has a very good reputation on FTE.78Explorer has a very good reputation on FTE.
If you bore a standard 302 block .30 over...is it a 306?
If not, then what size is it (in cubic inches)?
Thanks!
Scott
Old 07-26-2007, 10:26 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Yes.. it's 306 cu. in.
Old 07-26-2007, 10:28 AM
Is there a chart or formula somewhere to determine this? The guy who is disputing this will require some solid evidence....
TIA,
Scott
Old 07-26-2007, 11:02 AM
mprice mprice is offline
mprice is starting off with a positive reputation.
Engine Volume:
Bore Area (Pi R^2) * Stroke * Cylinders
302:
4.0" Bore, 3.0" Stroke
Bore Area = 2^2*Pi = 12.5664
12.5664 * 3 * 8 = 301.594
Bored .30 Over:
(2.15^2 * Pi) * 3 * 8 = 348.528
But, I am guessing you really meant .030 over:
(2.015^2 * Pi) * 3 * 8 = 306.134
Unless I am not understanding what you mean by .30 over then that would be a 349.
Calvin
Old 07-26-2007, 11:12 AM
yes...my bad...I meant .030 over.
Thanks!!!
Scott
Old 07-26-2007, 11:13 AM
What would a 460 bored .060 over equate to?
TIA,
Scott
Old 07-26-2007, 11:23 AM
Quote:
TIA,
Scott
Stock 460:
Bore - 4.36
Stroke - 3.85
Bored .060 over:
Bore - 4.42
(2.21^2 * Pi) * 3.85 * 8 = 472.592 (472 or 473 - your choice)
Calvin
Old 07-26-2007, 06:49 PM
petes79f150 petes79f150 is offline
petes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to behold
Old 07-26-2007, 08:53 PM
Thanks Guys!
Scott
Old 07-27-2007, 11:31 AM
385seriesHemi 385seriesHemi is offline
385seriesHemi is gaining momentum as a positive member of FTE.
The other displacement formula is Bore x bore x stroke x .7854 x #of cylinders
Old 07-27-2007, 11:39 AM
Cool!
Thanks!!!
89 302 bored .30 Preemo 1987 - 1996 F150 & Larger F-Series Trucks 2 12-07-2014 02:46 PM
Cubic Inches mtntop1 Performance & General Engine Building 5 08-29-2014 01:39 AM
300 bored 30 over redzepp35 New Member Introductions 1 09-15-2006 05:22 AM
302 bored .30 over? F-150Guy Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 03-21-2005 04:36 PM
Safe cylinder wall thickness? scottie2hottie Performance & General Engine Building 1 07-01-2004 11:03 PM
Tags
30, 302, bored, cubic, engine, ford, fored, inch, over
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
