NO--There is another thread within the past day on this. If you need a trailer brake controler get a Tekonsha Prodigy. Very easy to hook up since the wiring is already there under the dash and probably the best rated on the market for ease of use and reliability.
Just out of curiosity do you know if it is because the newer Super Duties have a different master brake cylinder (due to the larger brakes), or limitations within the ECM/PCM?
Those three are all that run the powertrain, but there is a body computer that controls many things that are not part of the powertrain, such as the trailer brake, interior lights, instruments, etc.
Please enlighten me as to the location of the "body computer" on the 03-07 F250/350 SD. All of the 03-07 SD i have had apart and all of the factory service manuals & wiring diagrams only show a PCM, FICM & TCM.
The PCM controls and talks to the FICM, TCM, trailer brake controller, lights, gauge cluster etc.
