Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-25-2007, 06:46 AM
98Ranger2.5 98Ranger2.5 is offline
Garage is empty, add now
98Ranger2.5 is starting off with a positive reputation.
98 ranger misfire intermittantly
Hi everyone I'm new here. I've oen my 98 ranger with 2.5L for about 6 years now i never had a problem i just hit 150,000 miles finally my first problem. I hope you guys here can help me out. Here is the problem. I start it up and runs fine after 10-20 minutes it starts to shake feels like a misfire and check engine light flashes on and off and slowly gets sluggish, i have step harder on the gas pedal to keep going. then while i am still driving all of a sudden like turning on a switch it stops shaking and i feel a increase in power everything seems to be fine then minutes later it happens again. here is what i have done so far. I replaced all plugs, wires, both coil packs. I pulled apart every plug under the hood i could find and checked them and reseated them. including injector plugs. checked for any vacuume leaks. i connected the OBDII scanner it comes up with only 1 code and that is (Detected Misfire in #2 cyl) i know i am getting spark to the #2 cyl.when i pull off the plug wire on both sides i got a great spark. any one with any ideas i can check thanks, Walt.
  #2 (permalink)
Old 10-19-2007, 01:14 AM
fordman26 fordman26 is offline
fordman26 is starting off with a positive reputation.
walt I have a 1991 Ford Ranger w/2.3L . I went through the same problems changing parts out. mine was still doing the same thing. then I replaced the ignition control module fixed all the problems. I drive it back to and from work everyday and never had another problem out of it since then, hopefully this may help you try one from a junk yard first it may save you some money new it will cost around $150.00 fordman26
  #3 (permalink)
Old 10-19-2007, 06:54 AM
Thanks fordman26 but i found the problem. it turned out to be a bad Fuel Injector on #2 cyl. The electrical part of the injector opened up. i found it by checking each fuel injector at the electrical plug with a multi-meter, all had 4.7 ohms across the two pins but the #2 cyl injector had zero ohms. I replaced it and the truck runs great again. you can read up on this forum ( http://www.ford-trucks.com/forums/63...on-a-2-5l.html )
On how 87 XLT and myself found and repaired the problem.
thanks anyway.
Tags
1998, 25, 98, backfiring, cyl, cylinder, engine, fine, ford, misfire, misfiring, missfire, ranger, runs, shake
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
