best performance mods for 5.4 L
whats the best bolt on performance mods for the gas engine, there are so many different things and manufacturers its hard to decide
2004 F250 SD
9" lift 37" Iroks
5.4L V8
Im lookin to get more HP but want the best recipe for increased torque too.
BTW, why cant I find the option to add a signature, I dont see that option it in my profile or anywhere in the UserCP for that matter
2004 F250 SD
9" lift 37" Iroks
5.4L V8
2004 F250 SD
9" lift 37" Iroks
5.4L V8
2004 F250 SD
9" lift 37" Iroks
5.4L V8
As for your truck, the best performance mod you can do, especially with the 37s is to regear your differentials. 4.30s or even 4.56s would increase your torque and pulling power. Surprisingly enough, it doesn't seem to hurt fuel economy. Some 5.4 owners even report increased economy around town with the lower gearing.
ok as I stated before, I already have an AFE cold air intake
I should have my cut-out flares and 41's on in about a month, then Im looking to go with 4.56 gears, I want to change the exhaust also and I was thinking MagnaFlow or Flowmaster.......what are you guys opinion on the exhaust?
I also want to put in a chip/programmer but I dont know NOTHING about them so I dont know what tuner to go with.
When I did my car I sent Superchip all my new engine stats, new gear ratio, exhaust size, tire size etc etc and they custom burnt a chip just for my car and it works great. But I dont plan on changing internals on this engine, I just want to maximize the potential hp of the stock engine.
on
Originally Posted by heidiandmax
In gears I would go with 4.88/5.13.They would get you closer to a stock ratio.
I would get an SCT SF/XCal2 and take it to the dyno and get it dyno tuned at a local dealer. A premium gas tune at the SCT dyno should be able to pick up more than 30hp and 30ft lbs, not to mention adjusting the tranny and tons of other parameters.
I believe Comp cams makes a set for the 5.4 that will give 30-40hp gains.
A set of headers will help.
Or look for a blower. The gears are the main thing need first.
Also be sure to post pics when finished.
wannagetrdone
12-23-2013 10:13 AM
dan_s_johnson
1997-2006 Expedition & Navigator
07-15-2003 07:20 AM
