no there isn't. what you need is to find is a servo lettered ((D)) this is one of the more commom servo's it has an aluminum piston with 2 seals on it for more positive shifts, plus the piston area is alot bigger than a N servo. other lettered servo's if you can find them are the lettered servo's from small to big are J- G- H- and the mack daddy the R servo. also if you can find a letter J or K actuator arm for the intermediate band will help greatly, but these are very hard to find. i think the D servo will do you just fine works super in my C-6 ...
what type of car-truck did the D servo come in?I have a small block 4X4 C6 and that also has the N servo.Can the intermediate band and actuator arm be changed with out taking the trans apart?
