Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Competition Diesel racing, sleds, dynos, power tuning and max performance.
  #1 (permalink)
Old 07-22-2007, 06:49 PM
tex4431 tex4431 is offline
Garage is empty, add now
tex4431 is starting off with a positive reputation.
Allison 6 speed behind a 6.0L
Has anyone put an Allison 6 spd behond a 6.0L powerstroke? If so what do I need to make it work?
  #2 (permalink)
Old 07-22-2007, 07:05 PM
cabinetmaker00's Avatar
cabinetmaker00 cabinetmaker00 is offline
cabinetmaker00 is starting off with a positive reputation.
what's wrong with the six speed you got .
__________________
http://img153.imageshack.us/img153/6...edgrillnv9.gif
2006 f250 cc,sb,4x4,6.0.
zoodad,sc1805, 4 in lbss exhaust.
tint.
  #3 (permalink)
blackhat620's Avatar
blackhat620 blackhat620 is offline
blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.
Quote:
Not that i know of. But to make it work you would need an adapter plate to bolt it to the motor, not sure of the length difference in the cases and you would need a computer to control it at very the minimum.Probably some other adapters as well.
This begs the quesion why would you want to do this? The 6spd Allison is Not superior to the 6spd Torqueshift. The Torqueshift takes more abuse than the Allison.
__________________
Courage is being scared to death---and saddling up anyway. -John Wayne-
06 F350 CC SB 6.0 4x4, Suburban Ford (Thanks Ernie )
“... there is no shame in not knowing. The problem arises when irrational thought and attendant behavior fill the vacuum left by ignorance.” ― Neil deGrasse Tyson
  #4 (permalink)
Old 07-22-2007, 08:07 PM
duffman77's Avatar
duffman77 duffman77 is offline
duffman77 is gaining momentum as a positive member of FTE.
Allisons have been used behind the 6.0 powerstroke in the F650s so it is possible. Here is a link to the 2007 build guide. Note its the 5 spd allison.
http://www.commtruck.ford.com/ctw/News/CatalogLR.pdf
  #5 (permalink)
Old 07-22-2007, 08:24 PM
MIKE1646 MIKE1646 is offline
MIKE1646 is starting off with a positive reputation.
The Torqueshift is a 5speed, not a 6.
__________________
06' F250 PSD cc King Ranch
  #6 (permalink)
Old 07-22-2007, 08:50 PM
Quote:
The Torqueshift is a 6 speed and uses 5 at any one time depending on load and driving conditions.
__________________
  #7 (permalink)
Old 07-22-2007, 10:32 PM
6L PWR 6L PWR is offline
6L PWR is gaining momentum as a positive member of FTE.
Quote:
I agree with that!! I gotta buddy that's only done a chip and exhaust and has had to rebuild his Allison twice. I haven't touched my 5R110W except for a Torque Converter and I've dyno'd at 586.4HP and 1204 lbs-ft. I race her on the weekends and drive her daily all week. Ok, so I mostly race her around all week too, but dang it, it's mine to play with!
__________________
RETIRED- NO LONGER ON THIS FORUM
  #8 (permalink)
Old 07-22-2007, 10:33 PM
dc3655 dc3655 is offline
dc3655 is starting off with a positive reputation.
Don't be fooled by the Allison name badge. In my experiences with the Torqshift and the Allison, I definitely think the Torqshift is a far superior tranny, not to mention that it will take a lot more power without needing an update kit like the Allison needs. I compared the two descending down a 8% grade while towing the same boat and the Torqshift did a much better job at maintaining the speed as well as not overheating. The Allison is at max capacity with the power levels of the current Duramax output, whereas the Torqshift is barely over half capacity with what the PSD is putting out. Think it over long and hard before going down a costly road.
  #9 (permalink)
Old 07-22-2007, 10:34 PM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
FTE *******
SpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to all
Quote:
Very well said
  #10 (permalink)
Old 07-22-2007, 11:55 PM
Blackhat620 check the Ford web site the Torqshift is a 5speed.
http://media.ford.com/article_displa...ticle_id=12092
__________________
  #11 (permalink)
Old 07-23-2007, 12:22 AM
BC Powerstroke BC Powerstroke is offline
BC Powerstroke is starting off with a positive reputation.
To clarify those that do not know the torque shift actually has 6 forward gears but it uses a strategy of 5 of the 6 when cold and different 5 strategy when warm. I can't recall if it is 3rd or 4th that gets skipped depending on if it is warmed up.
Because it uses only 5 forward gears in any strategy it is known to be a 5 speed tranny. Contrary to the newer Alison that uses all 6 forward gears regardless warm or cold operation.
Stock tranny form form my opinion the torqueshift is better than the Allison - marginally; contrary to the reputable name. If your are considering going through the trouble of pulling an Allison apart to improve it for your high HP needs and more trouble and money to put it behind a powertroke it would appear more economical and easier to get a reputable trannies from company such as Suncoast for the best torqueshift.
My opinion but eveybody will have one.
If you or someone else goes ahead with an Allison tranny behind a 6L please keep us informed.
__________________
03-6L 4x4 CC SRW 3.73 Auto
Level Kit, 35"Mickeys, 20" Wheels
4" MBRP TB, Intakes Elbow
Gauges, Oil By-Pass Oil Filter, Bilistien shocks
Dual Stabilizers, AGR Pump, Synthetics
Power Slot Rotors & Hawks Pads
Moog ball joints, energy bushings
Optimas, 24" Wipers, 2008 Diff. Cover
SCTII-Spartan tunes & EGR Block-off
  #12 (permalink)
Old 07-23-2007, 01:20 AM
Check the service manual it is a 6 speed. The transmission uses two different shift stategies depending on engine temperatures.
Cold Engine = 1,2,3,4 & 6
Warm Engine = 1,2,3,5 & 6
Gear Ratios"
1st = 3.09
2nd = 2.20
3rd = 1.54
4th = 1.09
5th = 1.00
6th = 0.71
The TorqShift also has the "Tow Haul" mode which alters the shift points based on load and driving style.
__________________
  #13 (permalink)
Old 07-23-2007, 07:21 AM
wiingnut's Avatar
wiingnut wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
Blackhat and BC are correct. The 5R110 was developed as a six speed. It has been marketed as a 5 speed because of the close ratio between 4th and 5th and how it was calibrated.
__________________
08 F350 SRW KR CC LB 4X4 Dark Copper Metallic V-10/Torque Shift, Loaded UP w/ Fac Nav and rear DVD
12 Escape Limited
  #14 (permalink)
Old 07-23-2007, 07:51 AM
poppie poppie is offline
poppie is starting off with a positive reputation.
find it funny how people get cought up in a NAME,the chevy allison 1000 IS NOT the school bus,garbage truck,dumptruck, motorhome trans that gave allison it's great name,so you have an allison in your chevy/gmc,so what,you just got snuckered,it's all a name game,just like best buy is not alway's the best buy,i've seen radio shack beat them on price,they just have more choice's than radio shack.
  #15 (permalink)
Old 07-23-2007, 09:56 AM
chrisd0610 chrisd0610 is offline
chrisd0610 is starting off with a positive reputation.
There is a company out there selling an adapter plate they also do Cummins conversions and sell all the parts. www.destroked.com
Tags
08, 5r110, 5speed, 60, adapter, allison, chevy, conversion, ford, plate, powerstroke, put, speed, torqshift, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
