92 explorer won't start
Old 07-21-2007, 11:25 PM
BanjoJim's Avatar
BanjoJim
BanjoJim is offline
92 Explorer Had no prior starting problems, Shut engine off one day, would not start again. Changed fuel filter, fuel pump, fuel pump relay, checked fuel shut off switch and that was ok. Disconnected fuel line at filter, cranked engine but Fuel pump does not pump. Need more ideas! Grateful for any help.
Old 07-23-2007, 05:47 AM
marragtop's Avatar
marragtop
marragtop is offline
Run a hot wire directly to the fuel pump to see if it runs. If it does, then you know the problem is between the ignition and the pump. Possibilites include the FP relay and the inertia switch. Use a test light at the inertia switch is see if you are getting juice. If not, then check the FP relay.
Old 07-23-2007, 08:05 PM
redwing76's Avatar
redwing76
redwing76 is offline
Fuel pump relay.
Ps. get a newer car.
The following users liked this post:
Old 07-24-2007, 11:08 AM
BanjoJim's Avatar
BanjoJim
BanjoJim is offline
Thanks, can you tell me exactly how to do the hot wire? Already changed the fuel pump relay with no result. Is the inertia switch the same as the emergency shut off switch in the cab under the carpet on the passenger side?
Old 07-24-2007, 11:11 AM
BanjoJim's Avatar
BanjoJim
BanjoJim is offline
Originally Posted by redwing76
Fuel pump relay.
Already changed the relay with no result. Any other ideas?
Old 07-24-2007, 11:41 AM
redwing76's Avatar
redwing76
Well, hate to say it but sounds like the pump. You know where it is right?
In the tank, not fun.
Good luck with the fix.
Old 07-24-2007, 11:52 AM
marragtop's Avatar
marragtop
Have you checked to make sure you have power to the pump with the key turned on? Also, make sure that the plug/wire on the bottom of the inertia switch is secure.
Old 08-20-2007, 10:10 PM
Tradster's Avatar
Tradster
Tradster is offline
Don't know if you have already solved your problem but I had just swapped out an engine on a 92 Explorer. After the swap, had the same symptoms. Turned over, had spark but no gas. My case, it was the inertia switch located inside on passenger side floor under the carpet. Just needed a reset, push of a button, and it fired right up.
markjones333
01-12-2015 11:42 AM
markjones333
01-11-2015 09:32 PM
drjoe171
09-20-2010 06:04 PM
russell2rx
04-13-2003 07:58 PM
92Roger
08-25-2002 11:14 PM
Quick Reply: 92 explorer won't start
