Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-21-2007, 10:51 PM
dcara is starting off with a positive reputation.
Supplemental Tranny Cooler
I know that my truck has 2 stock tranny coolers, one at the bottom of the radiator and one up by the AC pump. Is it the one up by the pump that is replaced/upgraded. Could some one explain a little about recommended tranny coolers upgrades.
Doug
99F250PSD7.3L4x4
Heavy Duty TC
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-21-2007, 11:45 PM
user
8tsixt is starting off with a positive reputation.
Everybody around here puts the 6.0 cooler.
__________________
1998 Camaro SS (toy)
1986 Buick Regal T Type GN (toy)
1997 Yukon 4X lifted
1990 Bronco 351w (project)
2007 Suburban (family wagon)
2002 Passat (commuter)
2004 Nissa Sentra (commuter)
2000 F350 cc dually, 2wd, automatic, 313,000 miles, 6637, Ccv, towing chip, 05 headlights, hutch and harpoon mod.
  #3 (permalink)
Old 07-22-2007, 12:16 AM
bigtorque is starting off with a positive reputation.
humm, i dont recall one by the AC pump, most upgrade the one at the bottom of the radiator.
--my buddy just added the tru-cool from i think dieselsite, he said it dropped his tranny temp about 30 deg.---thats a huge difference whey your talking 180 deg. to 150 while towing.
__________________
03 F-250 7.3 PSD/CC/SB/4X4--
BIG THANKS TO ---- RAGIN DIESEL - DP TUNER - BLACK CLOUD DIESEL- DIESEL SITE - ITP DIESEL - DIESEL INNOVATIONS - HANSONS TRANSMISSIONS - NOTHERN DIESEL PERFORMANCE - AMSOIL PERFORMANCE PRODUCTS AND THE BEST IDEAS FROM GREAT FOLKS AT FTE.
  #4 (permalink)
Old 07-22-2007, 12:34 AM
strokin_it7.3's Avatar
Overfueled User
strokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to behold
I have a 6.0 cooler. In the 2001 (it may be 01, possibly 02) and newer trucks, they have a second aux. cooler in the radiator. I believe the 6.0 cooler i have has to work extra hard to wick away the extra 200* heat of the coolant when my transmission is only running 140*.
__________________
02 F-350 with lotsa bling, some you see, some you don't.
Quote:
Originally Posted by Tenn01PSD350 View Post
Be careful with that 80E Tune.
  #5 (permalink)
Old 07-22-2007, 01:00 AM
warrens250 is starting off with a positive reputation.
Quote:
Doug
99F250PSD7.3L4x4
Heavy Duty TC
The second cooler is out in front of the radiator, not at the AC pump. The easiest upgrade is to add a 3rd cooler by putting it out in front of the radiator up higher than the one that is there, then reconnecting the tubing so that it is in series with the one below it. That is easiest to do, and adds a whole lot of extra cooling rather than substituting a bigger cooler for the one that is already there. The big Trucool, without the built-in automatic bypass is easy to install and adds more than enough extra cooling.
You need to get underneath and inspect the routing of the tranny oil line coming from the front of the tranny to the coolers. Then identify the line going to the existing cooler in front of the radiator and the line coming back from it and returning to the tranny. It is the line coming back you need to cut into. Then connect a new line to the cut line coming from the existing cooler and run it back in front of the radiator to the new cooler, and another new line from the outlet of the new cooler to the cut line running back to the tranny. This puts all the coolers in series; first the radiator cooler, then the old oil-to-air cooler in front of the radiator, then the new oil-to-air cooler in front of the radiator. Along the way you need to figure out how to get the grill off to mount the new cooler and connect the lines. Thats it. I did it, then verified I still had more than the minimum oil flow rate specified by Ford. Be sure that the lines are protected from rubbing on anything due to vibration. I now have plenty of cooling to tow my big 5th wheel in hot weather.
Warren
__________________
02 PSD, F250, 4X4, Auto, Jody Tipton's chip with 40 tow and 80 Econ modes, Kwik NAPA Filter mod, 4" Turboback exhaust, TC lock switch.
  #6 (permalink)
Old 07-22-2007, 05:03 AM
jtharvey's Avatar
Rough & Ready
jtharvey has a great reputation on FTE.jtharvey has a great reputation on FTE.jtharvey has a great reputation on FTE.jtharvey has a great reputation on FTE.jtharvey has a great reputation on FTE.jtharvey has a great reputation on FTE.
If I'm not mistaken, the cooler at the bottom of the radiator is the power steering cooler. Is it small, approximately 4" x 10" in size? If so, that's power steering. Follow the lines and you should see where they go.
The only tranny cooler is directly in front of the radiator, behind the A/C condenser. What is this one you speak of by the compressor? In the engine bay? Like others suggested, the 6.0 cooler works well.
Oh, and Kris, the thru-radiator cooling started mid year of the 2000 model...I've got it on my truck.
__________________
Jeremy 2000 F-350, CR 5.9
Conversion complete!
See My Webshots for more.
  #7 (permalink)
Old 07-22-2007, 08:03 AM
Oops!
Doug, I didn't notice you have a 99. There is no auxiliary cooler in the bottom tank of your radiator, as there is in my 02. Sorry. You only have the single oil-to-air cooler in front of the radiator. You should still add a new oil-to-air cooler in series with that one. Be sure you check to see you have adequate oil flow according to the Ford spec, which I don't know the value of for your truck.
Warren
__________________
  #8 (permalink)
Old 07-15-2008, 04:16 PM
curtisch is starting off with a positive reputation.
6.0 cooler
Is there a link to the 6.0 cooler? I wouldn't know if I'm asking for the right thing with just that description.
Thanks!
Curtis
  #9 (permalink)
Old 07-15-2008, 05:57 PM
MTDewX's Avatar
MTDewX is starting off with a positive reputation.
Contact FTEfordpartsguy, "supporter" and he has teh coolers. I got one shipped to my door for $287. adn it works great.
Ed will reply with any questions you have on his site.
Good luck
its also an easy job to do.
  #10 (permalink)
Old 07-15-2008, 06:03 PM
FTE/PARTS-GUY's Avatar
FTE Sponsor
FTE/PARTS-GUY has a good reputation on FTE.FTE/PARTS-GUY has a good reputation on FTE.FTE/PARTS-GUY has a good reputation on FTE.
Good luck
Everyone has been using 5C3Z7A095CA
THANKS FOR THE REFERRAL!
Ed
__________________
  #11 (permalink)
Old 07-15-2008, 06:34 PM
03F2507.3's Avatar
03F2507.3 is starting off with a positive reputation.
Quote:
Warren
How do you check this flow rate?
__________________
03 F250 7.3 CC SB FX4 Lariat, WW, A/R 1.0 exhaust housing, No Wastegate, EBV delete, AIH delete, 6637 w/ Petes cover, Zoodad, BTS VB, Tru-Cool, 203* stat, HD alternator, Foil delete, Autometer Ultra-Lite II boost, egt, trans temp, SCT tuner, 4" Magnaflow exhaust, remote start, WVO conversion.
  #12 (permalink)
Old 07-15-2008, 06:47 PM
kjswensen is starting off with a positive reputation.
i installed the TruCool. dropped my temp 30 deg and it was a lot less expensive then the 6.0 cooler.
__________________
2001 F-350, 4x4, CC, LWB, 4” MBRP, 6637 w/ pete's cover, zoodad, foil delete, Tru-cool, ISSPRO Gauges
  #13 (permalink)
Old 07-15-2008, 09:01 PM
03F2507.3's Avatar
Got my tru-cool today from Dieselsite.
Want to know how to check the flow before I install it so I can check it???
__________________
  #14 (permalink)
Old 07-16-2008, 12:33 AM
mueckster's Avatar
Redneck Wrencher
mueckster has a very good reputation on FTE.mueckster has a very good reputation on FTE.mueckster has a very good reputation on FTE.
Read this near bottom of the page under "Frequently Asked Questions, Testing, And Test Results". http://www.dieselsite.com/index.asp?...ROD&ProdID=205
__________________
-Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner, AFE II w/ Pete's Cover, ATS housing, Zoodad, SS HPX, IAH delete, 203* stat, Phantom gauges, MAP Reg, tank mods, DIY HD 4R100, 4" MBRP exh, coolant filter, shimmed FPR, Turbo Master, CCV oil trap, Procomp lift pump, CCK, TruCool, EBPV del, 140v IDM, GP LED, Foil del
PAA Member #62
  #15 (permalink)
Old 07-16-2008, 04:58 AM
03F2507.3's Avatar
Thanks for the help
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
