No Brakes........Need Help asap
I was driving down the mountain today and my pedal lost all pressure.... my ABS and E-Brake light came on got under the truck and there was fluid coming from the drivers side wheel.....I knew i needed new brakes but damn!!! Where is the fluid coming from the caliper?? When i replace it am i going to have to bleed all the brakes or just that one..... Also is it safe to drive home thats what i really need to know.. I have been downshifting and pumping the brakes, but eventually it will run out of fluid
on
7000 lb of truck is pretty dangerous when you cannot stop it. And I don't think the insurance company will look too kindly to paying out on an accident caused by no brakes. A tow bill is a LOT less expensive than the liability. Beyond measure.
It shouldn't be hard to find the leak, just remove the tire and have a partner step on the brake pedal and you will see where it comes out. Take it from there.
Don't bother with the brake clean in a can. Brake fluid is very water soluble (believe it or not) so get a spray bottle of your favorite kitchen cleaner (not oven cleaner!!!) and soak everything with that stuff and then rinse with plenty of water. Even dish soap, water in a bucket and a brush will work better than brake clean.
Very easy. Unloosen lug nuts, jack up and support, remove lug nuts and wheel. Remove brake line from caliper and please in a 2 liter bottle or something to catch fluid. Remove caliper bolts and pry off caliper.
If you're going to do pads and rotors, then remove caliper bracket bolts and then slide off rotor. With the caliper bracket, remove the caliper slide pins and lube. You could have them frozen. Take the time to get them removed, or one of your pads will wear fast.
Reassemble and bleed all 4 brakes (very easy). Get a partner. Pump up, hold, and open bleed screw, drain, tighten screw, unlease brake and pump up again. Repeat until no air comes out of all 4 corners.
Going from memory on this post, I hit the high points and might have forgotten some minor details.
focusdriverlx20
07-07-2010 02:50 PM
bonesbut
10-21-2006 01:59 PM
irontruck
03-06-2005 02:45 AM
Caleb1
01-28-2005 02:42 PM
