Odometer Readouts - Ford Truck Enthusiasts Forums
West Virginia Chapter Join Chapter, Leader: Archion
Odometer Readouts
Old 07-21-2007, 10:33 AM
msgtg's Avatar
msgtg msgtg is offline
msgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to behold
Odometer Readouts
I just learned that there's a way to get additional data from the odometer.
Follow the link for the info.
http://www.ford-trucks.com/forums/63...new-today.html
WOW!!! I just went and looked at mine.....
There are 49 data fields!
Gage= does a gage sweep and resets to current readings
888888.8 but the first 8 has dots in the two circles, the second 8 has the dot in the bottom circle and there's a hash connecting the first two 8s at the top...the other 8s are all normal
bulb= llluminates all the cluster bulbs
PF 3346= I have no clue
SF 0E05= I have no clue
0091155= I have no clue
r 0402 (flashing) fail= I have no clue
nr 0402= I have no clue
EE01= I have no clue
dt 443A= I have no clue
CFI 60= I have no clue
CF2 00= I have no clue
CF3 00= I have no clue
CF4 00= I have no clue
dtc none= I have no clue
EnG 000= I have no clue
riC 000= I have no clue
tac (moving display showing) 0653 to 0639= current tach
F (moving display showing) 198 to 200= I have no clue
FP 206= I have no clue
079c= I have no clue
oil 000= I have no clue
064 TF= I have no clue
br (moving display reading) 122-125= I have no clue
batt (moving display reading) 14.2 to 14.3=alt output to battery?
rhEO 00= I have no clue
Prnd 40= I have no clue
PAr 0= I have no clue
door 00= I have no clue
Stbt b= I have no clue
CHE 01= I have no clue
PA 80= I have no clue
PB 11= I have no clue
PE 18= I have no clue
P6 20= I have no clue
PH 90= I have no clue
PP 98= I have no clue
PS (moving display reading) 8F to 9F= I have no clue
PT 25= I have no clue
PCAn 1F= I have no clue
Ado 000= I have no clue
Ad1 255= I have no clue
Ad2 255= I have no clue
Ad3 (moving display reading) 088 to 089= I have no clue
Ad4 000= I have no clue
Ad5 255= I have no clue
Ad6 (moving display reading) 181 to 184= I have no clue
Ad7 (moving display reading) 140 to 142= I have no clue
Then it starts again with gage.
ANY help here would be appreciated. Especially with the one that reads the flashing FAIL.
Thanks!
Joe
Old 07-21-2007, 09:47 PM
5_labsownus's Avatar
5_labsownus 5_labsownus is offline
5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.
Thats interesting! I did it to the ambulance today and it worked. It is a 2004 SD and it came up with "Gage" and they pegged and returned and could scroll through the options!
Old 07-21-2007, 10:01 PM
msgtg's Avatar
Teachin the old dog new truck tricks!
Old 07-22-2007, 08:49 AM
Bark bark gggggggrrrrr bark bark
Old 07-22-2007, 11:09 AM
msgtg's Avatar
I can just imagine how the two dogs are looking at you right now! LMAO!!!
Joe
Old 07-22-2007, 08:59 PM
As I typed it 3 Chihuahuas in my lap. My 2 and a friends!
They alwasy look at me like I have lost my mind.
Old 08-12-2007, 10:39 PM
Joe this old dog learned another new trick! My 02 Escape does the same thing when I hold the button in and best I can tell lists the same you listed!
Rod
Odometer/Reset button menu SBV45 6.0L Power Stroke Diesel 8 07-07-2016 04:04 PM
faulty link between PATS module and EEC V Peanut39350 1997 - 2003 F150 1 05-14-2015 06:47 AM
cool trick supposed to work on f150 too todd31277 1997 - 2003 F150 9 04-15-2006 11:17 PM
oil change creates no pressure/knock frosch91ranger 4 Cylinder Engines 13 12-06-2004 07:04 PM
Diagnostics via Odometer Button daigles 1997-2006 Expedition & Navigator 2 07-31-2003 07:07 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2002, 3346, 60, 73, 80, 8888888, cf2, code, diagnostic, display, ee01, ford, odometer, pf, pf3346, powerstroke, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
