Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 07-21-2007, 08:58 AM
MikeSDK's Avatar
MikeSDK MikeSDK is offline
Garage is empty, add now
MikeSDK is starting off with a positive reputation.
Less Power using Bio?
Hi folks-
I've seen a some posts from various people both on these and other forums who state that their vehicle produces less HP when running bio than when running regular #2 diesel.
Is there anything to this? From the reading that I've done, it sounds to me like bio has a higher cetane level, better lubricity, etc, so it seems kind of counter- intuitive to me that it would lead to lower HP output.
Does anyone have any further explanation that can enlighten me?
Thanks!
__________________
Mike
2002 F-350 Lariat CC DRW 4x4 7.3L PSD
Isspro EV A-pillar, AIS intake w/ fender sleeve, 5' exhaust, KCM HPX, Tru-Cool Max, BTS VB, RDP FRX, AIH delete, plenum inserts and boots, and Casserly Stage 1 Injectors, 38R and DP Tuner (live tuned) thanks to the gang at RRE 2012!
  #2 (permalink)
Old 07-21-2007, 10:10 PM
willbd willbd is offline
willbd is starting off with a positive reputation.
I did a quick google and found this web page.
http://www.cytoculture.com/Biodiesel...%20PERFORMANCE
Here is a quick quote from this web site.
In the Volvo marine diesel engine study in Tennessee (110-HP, 2.39 L, 4-cylinder, direct injection engine), a tractor dynamometer was used to measure power outputs under selected loads through an engine-mounted reverse drive gear. Exhaust emissions were also tested along with fuel consumption tests under various loads. The conclusions of these tests were that power produced from 100% soy methyl ester Biodiesel was from 2 to 7 percent less than produced from petrodiesel, depending on the load-speed point. However, at or near maximum throttle (3,800 rpm), the two fuels performed the same. Interestingly, at the lowest engine speed (1855 rpm) at full throttle under heavier load, there was a 13% increase in power with Biodiesel as compared to petrodiesel.
The Tennessee study indicated that using 100% Biodiesel in marine direct-injection diesel engines, with design and construction similar to the Volvo test engine, could be recommended without any significant, noticeable differences in operation, power performance and fuel usage.
In the 1998 study at the Southwest Research Institute on Biodiesel effects on diesel engine performance, engine power in the 1997 Cummings truck engine operating on the B-20 blend was at 98.5% of the power attained with low sulfur No. 2 diesel. At 100% Biodiesel, the engine generated 92% of the power. For a Detroit Diesel truck engine (1997), the power was 98% with the B-20 and 92% with the neat Biodiesel.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
  #3 (permalink)
Old 07-24-2007, 10:21 AM
jimmye4golf jimmye4golf is offline
jimmye4golf is starting off with a positive reputation.
Ive been running B50 in mine and my last tank is basically B75........I cant tell a bit of difference in power. Quietness yes, power no.
  #4 (permalink)
Old 07-24-2007, 08:32 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.
Here is an article to read from Case/IH ag equipment which talks about power loss in middle of article. Enjoy! http://www.caseih.com/highlights/hig...3&recordid=193
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #5 (permalink)
Old 07-24-2007, 11:00 PM
good article!!!!!!!!!!!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
