wiring a signal stat 900
My 7 wire signal stat 900 needs a 3-prong flasher. Is there a special model/type that is required? I bought one from Auto zone but it will not work when wired using the diagram of ...
signal stat YELLOW to "load", Signal stat BLUE to "pilot" and the other is 12V.
I have to leave the BLUE un connected, and use that tab as GROUND, the YELLOW to load, and the other to 12+.
But it flashes too rapidly, like a bulb out.
(in other words the modern flasher tabs are marked Positive (+), Ground (-), And (L).
So is there a flasher model still marked "Load" "Pilot" and (+12V)???
What does "pilot" (the blue wire) mean???
Reamer
Reamer
"Pilot" is the indicator in the SignalStat unit (single bulb that moves with the handle, to the appropriate lens). Here is the official wiring diagram.
I would use this scheme:
Flasher (+) = battery
Flasher (-) = Load (yellow)
Flasher "L" = pilot = blue
The flasher isn't one of those electronic ones, is it? I don't believe they will work.
Steve49841
04-07-2015 05:38 PM
SparkyRnD
04-06-2011 12:16 AM
