Drop Kit for a 4x4?
I'll try this again, this time with a little more tact. Keep in mind that a 4x4 is worth more than a 4x2, all else beeing equal. You could sell your ex and buy a 2 wheel drive version for less money, or find a newer one with lower miles for the same money. Think about it, if you don't use 4 wheel drive, what is the point of hauling around all that extra weight. With a 2 wheel drive, you would have less weight with potentially better mpg, the turning radius is probably tighter, and it would be easier to lower. The only draw back, is it may take more seaching to find a 2x4 ex with the options you want. Good luck.
i thought about lowering my f 250 4x4, and djm had kits for the trucks, if you want to check out the web site or even stylin concepts has the kit, the only problem is it is for the 1999-2004, and i have an 2005, and there is no kit you can just buy, must be custom made or some other type of set up.
Originally Posted by 6L PWR
I've been looking to lower mine for a while. I use 4x4 to launch on the strip. Try launching at a drag strip with the weight of this diesel and you just spin the tires. Yeah, there's lots of guys dragging 2x4's. They've done custom suspensions with four linked rear ends and the works to make them hook. I still need my truck to work. Boat launches are way to slick without the 4x4. Getting down into the horse pasture through the mud would be very difficult without 4x4 as well. Some of us need 4x4, but not all the ground clearance.
Originally Posted by Monsta
Lowering his F-250 is as simple as swapping the springs with an Excursion (as stated before). Y'all shouldn't make it sound like a difficult thing to do.
Lowering my F250 4x4
I know I'm several weeks behind this post, but it is exactly the same situation I have. I use my 2002 F250 CC PSD for towing a car trailer and daily driving. I've got my son's car seat in back and it's a tough for the wife to lift him up in there. If the truck was a couple inches lower it would be a little better. I need 4x4 for the occasional midwest winters and to climb the steep grades on my property, but don't need all of the ground clearance. You mentioned installing Excursion springs. I'm assuming this would be 2x4 EX springs and not 4x4, right? If you know of anyone that has their stock springs available, I'm interested.
