Need help- tailgate removal instructions - Ford Truck Enthusiasts Forums
Old 07-20-2007, 02:18 PM
Tarmac Tarmac is offline
Tarmac is starting off with a positive reputation.
I have an 06 F-150 with the "assist" built into the tailgate. Please tell me how to remove the gate, I will be using her as a truck in the morning and the gate will just get in the way.. Thanks
Old 07-20-2007, 06:05 PM
GordoPanocho's Avatar
GordoPanocho GordoPanocho is offline
GordoPanocho is starting off with a positive reputation.
Have you looked at the tailgate? Seems to me like you just pop it out of the groove on one side and then slide out the other side from its connection. That's why they're so easy to steal.
Old 07-20-2007, 06:22 PM
wildcard30's Avatar
wildcard30 wildcard30 is offline
wildcard30 is gaining momentum as a positive member of FTE.
Quote:
From the owners manual...
Tailgate removal
Your tailgate is removable to allow
more room for loading.
1. Lower the tailgate.
2. Use a screwdriver to pry the
spring clip (on each connector) past
the head of the support screw.
Disconnect cable.
3. Disconnect the other cable.
4. Lift tailgate to a 45–degree angle
from horizontal.
5. Lift right side off of its hinge.
6. Lift tailgate to a 80–degree angle from horizontal.
7. Remove tailgate from left side hinge by sliding tailgate to the right.
To install, follow the removal procedures in reverse order.
Simple answers to simple questions can be found in the manual....
Old 07-13-2008, 12:49 AM
redrush40 redrush40 is offline
redrush40 is starting off with a positive reputation.
That's it????
So basically the same removal instructions for the 1980-96 style trucks?
I have to remove my tail gate tommorrow as well...
Thanks for the tip,
TONY Z.
#40
Old 07-13-2008, 06:29 AM
svt2205 svt2205 is offline
svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.
Yup, that's it.
Old 07-13-2008, 08:43 AM
FatalErrorz FatalErrorz is offline
FatalErrorz is starting off with a positive reputation.
No...Bring it to my shop and I'll remove it for you. When you're done, bring it back, and I'll install it for you. Business is slow; support your local shops... (kidding)
Old 07-15-2008, 07:00 PM
baitmaster baitmaster is offline
baitmaster is starting off with a positive reputation.
I recently moved a refrigerator in my long bed. The darn tailgate almost fell off in the parking lot, that how easy they come off. I always keep mine locked for that reason.
Old 07-17-2008, 01:37 PM
EMB135Driver EMB135Driver is offline
EMB135Driver is starting off with a positive reputation.
Quote:
+1...my tailgate is only unlocked when I open it.....I was stunned to learn that GM trucks don't have locking tailgates, then I reasoned that no one in their right mind would ever want to steal one.
Old 07-17-2008, 04:03 PM
Arnold Kenyon's Avatar
Arnold Kenyon Arnold Kenyon is online now
Arnold Kenyon is starting off with a positive reputation.
Quote:
Originally Posted by EMB135Driver View Post
+1...then I reasoned that no one in their right mind would ever want to steal one.
It is the people who are not in their right mind that you have to worry about.
Old 07-20-2008, 04:37 PM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
FTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to all
...For those that didn't always keep the t-gates locked or in the up-right and locked position seem to use a couple of ty-wraps to keep the gate from Bouncing off of the "barrels".
Iirc... there were a posts/pics out on this...
Old 07-20-2008, 04:57 PM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
I read about the rash of tailgates getting stolen and I always lock mine up
yep, got a few tie wraps on my tailgate as well to keep it from "popping off" if there is something in the bed that pushes against the bottom edge when you are closing it. 1 guy had his tailgot pop off when a flat peice of cardboard pushed on the bottom edge
Removing tailgate moulding and tailgate nameplate. DanoF250 1967 - 1972 F-100 & Larger F-Series Trucks 4 11-27-2016 03:54 PM
new tailgate bla614 1997 - 2003 F150 6 01-12-2013 02:44 PM
Is there a Secret to Installing a '64 Tailgate Macs1964F100 1961 - 1966 F-100 & Larger F-Series Trucks 3 12-31-2012 10:20 PM
Tailgate step and handle awq134 2009 - 2014 F150 6 02-10-2010 12:35 AM
Tailgate removal 89 f-150 timberbuck 1987 - 1996 F150 & Larger F-Series Trucks 15 08-05-2002 12:08 AM
Tags
2002, 2005, 2007, 2008, 2011, assist, cable, disconnect, expedition, f150, f350, ford, id, lift, locking, removal, tailgate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
