how much R134a should go in? - Ford Truck Enthusiasts Forums
Old 07-20-2007, 02:20 PM
dbuck50 dbuck50 is offline
dbuck50 is starting off with a positive reputation.
I have an evacuated/converted to R134a 93 F150 with 5.0.
How much R134a should go into this system to properly charge it? Thanks.
Old 07-20-2007, 02:37 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Usually, anywhere from 70-80% of the weight of the original R12 charge is about right. Start with the 70% and check performance. Add an ounce at a time until you get ideal performance.
Steve
Old 07-20-2007, 05:21 PM
2000Ford2000's Avatar
2000Ford2000 2000Ford2000 is offline
2000Ford2000 is starting off with a positive reputation.
If you're doing it without gauges, then your doing it wrong.
Old 07-21-2007, 07:33 AM
Quote:
Who said anything about "without gauges"?
Old 07-21-2007, 12:01 PM
hhott71 hhott71 is offline
hhott71 is gaining momentum as a positive member of FTE.
The 93 parts (cond, evap core etc) are the same size as the 94 -95 models.
So use that charge weight. which is 33 oz
Old 07-21-2007, 04:26 PM
!!!!ABSOLUTELY WRONG!!! when converting to R134a.
If you do that, it will be so overcharged it will likely blow something out....
Steve
Old 07-22-2007, 07:41 AM
Who said anything about 'with gauges'?
Old 07-23-2007, 12:23 PM
Steve
Oh really.
91-93 models held 44 oz
94-95 models hold 33oz ,,,75% of what was used before in R12.
Same evap, condenser, comp volumes.
But hey I've only done thousands of retrofits in the past 19 years.
I was making the math simple for the question asked.
Old 07-23-2007, 04:05 PM
I interpreted "that charge weight" to be the R12 weight of 33 oz. Your post was not explicit in that the old R12 charge was 44 oz.
When placed in perspective with your additional information, your math is correct.
Sorry, but I took it the opposite way from what you meant and wanted to be certain that noobs didn't make a serious mistake.
Steve
Old 07-26-2007, 01:28 AM
Piffery1 Piffery1 is offline
Piffery1 is gaining momentum as a positive member of FTE.
I've done several R12 to R134A conversions and I always install a High Pressure Cut Out (HPCO) switch to prevent "blowouts" due to overpressure. Can't find them locally anymore so I bought the last two I needed from JC Whitney. With an HPCO I charge R134A to 85% of the R12 charge weight. OBTW, when you convert be sure you get a new accumulator that has desiccant compatible with R134A. Also, get an orifice tube (red/white) for R134A and adjust the compressor low side cycling switch for best performance. Check this link: http://www.forparts.com/techretrofit.htm
Has anyone retrofitted A/C on '93 F150 bf5113x 1987 - 1996 F150 & Larger F-Series Trucks 5 08-05-2015 08:47 AM
refrigerant kashrutcowboy 1987 - 1996 F150 & Larger F-Series Trucks 8 07-03-2015 08:25 AM
a/c Help R-12 replacement? brianmorgan17 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 06-07-2014 12:33 PM
How much PAG oil for a 1990 F250 A/C system CountryBumkin 1987 - 1996 F150 & Larger F-Series Trucks 3 07-06-2012 07:39 PM
how much R134... ducky17 1987 - 1996 F150 & Larger F-Series Trucks 6 09-15-2008 09:25 PM
Tags
04, 2001, 2003, 2004, 94, charge, e350, f150, f250, hold, mch, mych, quantity, r134, r134a
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
