guess this goes here
Originally Posted by xtrford
Oh, my bad. Your sig has a "supercharged 03 Expy", and I must have read too quickly cause it looks like at a glace that you have 2 rigs. I was assuming the Harly had the mods and the Expy was only supercharged.
I used to have a Silverado SS and from factory they only had 345 hp, not 395 hp. I don't think there will be a problem with you coming out on top......
Weight for the SS is 5300 lbs. Has the LQ9 engine, not the LS2. Runs a 14.9 sec 1/4 mile. Now if there are mods on the SS then it might be a different story.
Good luck and keep it safe!!
Originally Posted by 04markIII
buddy at work has a silverado ss. he is completely stock....(395 crank hp). my mods are in sig. vehicle weights are similar. i think it would be real close, but what do you guy thinks? we may do some runs against at ffw in august.
The Chevy SS weights in around 4947 LBS
Your truck comes in around 5600 Lbs
hes only got around 300hp or less at the tires so i think you would take him but it would be close, both HP to weight ratios are realy close!
