lug nut torque? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
lug nut torque?
Old 07-19-2007, 02:48 PM
earlybirds earlybirds is offline
earlybirds is starting off with a positive reputation.
lug nut torque?
1999 F250 Superduty 4x4 5.4liter
I read somewhere in this forum that wheel lug nuts should be torqued from 150 -165 ft. lbs. Does this include alloy wheels? Thanks in advance for any insight.
Old 07-19-2007, 03:17 PM
tortoisethunder tortoisethunder is offline
tortoisethunder is starting off with a positive reputation.
I believe this would be too much for alloys, I have Micky Thomson II's and do 125lbs. No problems.
Old 07-19-2007, 03:39 PM
I should have specified that these are FORD alloy wheels that came from the factory when I ordered my truck thru the dealership.
Old 07-19-2007, 03:42 PM
EaTmYtAiLpIpEs's Avatar
EaTmYtAiLpIpEs EaTmYtAiLpIpEs is offline
EaTmYtAiLpIpEs is starting off with a positive reputation.
I don't torque my wheels. I think a 300lb compressor with the impact gets them on tight enough ;-)
Old 07-19-2007, 03:50 PM
busdriver47 busdriver47 is offline
busdriver47 is starting off with a positive reputation.
i have 2005 F350 manual says 150 lbs have alloy wheels.
Old 07-19-2007, 03:51 PM
bryyce62's Avatar
bryyce62 bryyce62 is offline
bryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud of
Dude,
That's a great way to warp your brake rotors...you might want to re-think that strategy.
150 ft. lbs is about right, even for factory alloys.
gw
Quote:
Old 07-19-2007, 03:53 PM
that could be why when I got the truck those front rotors were SHOT. I was scared to step on the brake.
Old 07-19-2007, 04:14 PM
Biggziff's Avatar
Biggziff Biggziff is offline
Biggziff is gaining momentum as a positive member of FTE.Biggziff is gaining momentum as a positive member of FTE.
150 lbs ft
Old 07-19-2007, 04:36 PM
thechief96 thechief96 is offline
thechief96 is starting off with a positive reputation.
The torque that is stamped on my lugs that came from Alcoa for my Alcoas is 140 lbs.
Old 07-19-2007, 05:05 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Go read the thread from a few weeks ago where a Super Duty owner was towing a trailer across the Bay Bridge in San Fransisco and all his lugs sheared off of a rear wheel. He lost a wheel, he suspects because he rotated his own tires and overtightened the lug nuts.
He managed to get the truck and trailer off of the bridge without hitting anyone or anything, not sure how but he did.
Old 07-19-2007, 05:10 PM
ken kenmnedy's Avatar
ken kenmnedy ken kenmnedy is offline
ken kenmnedy is gaining momentum as a positive member of FTE.
its stamped on my lugnuts 150 with factory alloys
Old 07-19-2007, 08:23 PM
davhut davhut is offline
davhut is starting off with a positive reputation.
From the factory service manuals for 2000-2007 the spec is: 8-Lug M14 wheel bolts 224Nm or 165lb-ft for alloy or steel. You do have to use the correct lugnut type for each type of wheel of course. By the way, over torquing is very bad - 'bout garantied to have a bolt shear at some point. Over-torqued lug bolts should be replaced ASAP.
Old 07-19-2007, 08:51 PM
07250psd's Avatar
07250psd 07250psd is offline
07250psd is starting off with a positive reputation.
Please forgive me for jumping in this thread, but Hey, now got some answers for a thread I started a few weeks ago, but now,,, is there a difference in lug nuts for each factory type of wheels on an 07? Will the steel factory lug nuts not work on the factory alloys? I did it on mine - do I need new ones?
Thanks!
Old 07-20-2007, 12:15 AM
jake00's Avatar
jake00 jake00 is online now
FTE is my crack
jake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant future
the tire place told me 1150 lbs for my alloy wheels
Old 07-20-2007, 04:41 PM
Not positive on the steel vs alloy lug nut being different on all models / years. I do know that on most of the SD model years they are in fact different. The ones for alloy have an integral washer whlie the steel don't. Do NOT use the wrong ones. They will not work properly and are dangerous if used on the wrong wheel type.
jake00 - If yours are stock alloy wheels they should be 165lbs according to the book. Check with a ford service center to be safe.
Lug nut foothills321 1987 - 1996 F150 & Larger F-Series Trucks 2 12-05-2014 08:37 AM
Solid Lug Nuts cmcstotts 2009 - 2014 F150 1 08-29-2013 09:56 PM
lug nut torque? earlybirds Explorer, Sport Trac, Mountaineer & Aviator 8 11-06-2009 02:14 AM
Torque spec's jcee 2004 - 2008 F150 7 03-24-2009 08:41 PM
Wheel torque specification? samckernan 1967 - 1972 F-100 & Larger F-Series Trucks 3 09-03-2004 11:28 AM
Tags
2006, 250, 54, alloy, banks, f150, f350, ford, liter, lug, nut, pack, power, torque, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
