rear diff cover torque specs. - Ford Truck Enthusiasts Forums
Old 07-19-2007, 10:58 AM
Fxxer Fxxer is offline
Fxxer is starting off with a positive reputation.
I have searched high and low for the torque specs on the rear 12 bolt differential cover for my 2003 f150 4x4. I know how to change the fluid and I know I need high temp gasket sealer, because ford doesn't use a gasket. I do know that all vehicles have torque specs, but I thought I could find it on the forum rather than spending $25 on the service book. Any help would be great.
Old 07-19-2007, 12:11 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
33 ft/lb
Old 07-19-2007, 01:06 PM
Thanks again, that was all I needed.
Old 07-19-2007, 11:34 PM
BlueOvalFitter's Avatar
BlueOvalFitter BlueOvalFitter is offline
BlueOvalFitter is gaining momentum as a positive member of FTE.
Wink
If its an 8.8 Fel-Pro makes a gasket for it;
RDS-55341
Rear differential cover torque specifications Shadowsuave Clutch, Transmission, Differential, Axle & Transfer Case 1 04-17-2016 10:57 PM
NP435 fastener torque specs Tim_SoCal 1967 - 1972 F-100 & Larger F-Series Trucks 3 06-25-2015 06:06 PM
Torque specs - 400M valve covers jamjriii 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-08-2010 08:53 PM
Torque specs for rear cover - 10.25 Sterling folsomf250 1997 - 2003 F150 1 01-31-2009 11:45 AM
torque specs for calipers? fiddy Explorer, Sport Trac, Mountaineer & Aviator 1 08-26-2002 06:30 PM
Tags
02, 2002, 2005, cover, diff, differential, f150, felpro, fluid, ford, rear, spec, specic, specs, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
