Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > West Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
West Virginia Chapter Join Chapter, Leader: msgtg
  #1 (permalink)
Old 07-19-2007, 07:02 AM
msgtg's Avatar
msgtg msgtg is offline
1992 Ford F-150
My Garage
msgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to behold
Fuel Additive Question
I was recently at a Chev*** station adding Diesel Kleen after a fill up...just like I always do when the station owner (a local I know) walked over and told me that I didn't need to use any additive. He says that the company mentioned above adds it when they load the truck for delivery. Says he gets a pink slip showing how much was added to each truck load.
Can anyone chime in on this?
I add the DK primarily as a hedge against injector issues. The winter blend (white bottle) also has the anti-gel for cold temps so I use that when the temps drop. Bottom line is I feel it's an insurance policy for injector health.
Am I right or wrong?
Thanks,
Joe
__________________
03 F250 King Ranch Crew 6.0 4x4 92 F150 XLT SuperCab 4x2 03 Intruder Volusia 03 Ranger XLT
WV Chapter Lead JOIN THE WEST VIRGINIA CHAPTER CLICK HERE
We live in the Land Of The Free...BECAUSE of the Brave! My humble thanks to all Veterans, past and present
  #2 (permalink)
Old 07-19-2007, 09:14 AM
mech2161's Avatar
mech2161 mech2161 is offline
Garage is empty, add now
mech2161 is gaining momentum as a positive member of FTE.mech2161 is gaining momentum as a positive member of FTE.
I'm sure if you run the fuel from the mentioned station without adding DK you will be able to hear more noise from the injectors. I do add DK every time I get fuel.
As a test run your tank low then fill up at that station. Show the owner your not adding anything to the tank and take him for a ride. Then add the DK and go for another ride. Let me know what you find.
__________________
Kevin
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
  #3 (permalink)
Old 07-19-2007, 10:49 AM
msgtg's Avatar
1992 Ford F-150
My Garage
My basic plan was to ask around and see if other truck owners agreed with me.
I don't want to run the fuel without adding the DK unless I got some agreement from you guys that I'm not creating issues for my injectors. Then, I'd try the fuel without additive and see if I notice any difference.
Joe
__________________
  #4 (permalink)
Old 07-19-2007, 02:39 PM
msgtg's Avatar
1992 Ford F-150
My Garage
This response is from the FTE Members Forum:
Quote:
Originally Posted by Snowbunny
That particular station has always included their own additives at the time of the dump. The industry has always considered it to be a good product ~was a time that that was the only place I would buy~ unlike a few other places who get their gas imported from China and have water issues... However, I never drove for them, and only delived to un-branded (mom and pop) stations so I don't know exactly what it includes. And it's been a few years, so I'm sure the 'chemistry' has changed a bit. Here's a link to some of their info that may be helpful.
http://www.chevronlubricants.com/wor...dd/default.asp
Personanlly, I add DK too... I don't know if there's such a thing as 'too much' but there definitely is a thing as 'not enough' were this is concerned...
Good stuff if you ask me!
Joe
__________________
  #5 (permalink)
Old 07-19-2007, 10:44 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1997 Ford F-350
My Garage
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
The 03 injectors and pump should be able to handle ULSD just fine, but, there is no way that you can get or keep your fuel system to clean or to lubricated.
Yes all the fuel companies say that there should be enough lubrication in the ULSD for even the old diesel engines.
But that is not what we are seeing in the IDI forum.
I run Diesel Kleen in every tank of fuel in my truck as well.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #6 (permalink)
Old 07-20-2007, 09:24 AM
5_labsownus's Avatar
5_labsownus 5_labsownus is offline
1999 Ford F-250
5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.
Joe,
At work the mechanics said that Ford suggested using their additive but that Lucas additive is as good. We used both with the new low sulfur fuel and have not had any problems. It has cured some of the problems of we were experiencing like fuel pumps failing and low MPG. However the MPG never came back to the old fuel mileage. All of the fuel companies put additives in the fuel and they switch in this area about May and October for Spring and Winter. I am going to start with Lucas and see how my MPG goes!
And there are several other good additives like Amsoil additive if you can find it!
Rod
P.S. I will have the graphic Monday and get it to you ASAP!
__________________
Toby Wan-Knobey
WV Chapter Member
This is my RCA dog look!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
