hard starting
Yep they do. Has to do a lot more with oil temp than anything else. You're in Canada, so I guess the definition of "warm weather" might vary a bit. However I've found out how important glow plugs can be even in the summer. Last year the GPR went out, and it was very difficult to start when the engine was cold and the outdoor temps were in the 80's.
However, after re-reading your post I need to ask: is it hard to start at any time no matter what the engine temps are, or just that first morning start before the motor had a chance to warm up?
on
Get an ohm meter (get a digital readout), you can check your glow plugs/injectors by unconnecting the 9 pin connectors at both of the valve covers (near top edge) and use the following info:
GGIICIIGG
G = Glow Plug
I = Injector +
C = Injector -
Ohms between the G and block Ground should be 0.1 - 2.0 ohms.
Ohms between the I and C one at a time if one or more is > 5 ohms, it will point to the side's gasket connector or UVC harness being shorted.
Also check the oil level in your HPOP reservoir by removing the fill screw on top.. should be about 3/4" from the top.. you need enough oil for a quick start..
GGIICIIGG
G = Glow Plug
I = Injector +
C = Injector -
GGIICIIGG
G = Glow Plug
I = Injector +
C = Injector -
GGIICIIGG
G = Glow Plug
I = Injector +
C = Injector -
This will sound dumb but where is the HPOP reservoir?
Phillip Guidry
08-20-2000 08:31 PM
