Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-18-2007, 09:26 PM
mmorto is starting off with a positive reputation.
Changing spark plugs in an 8 plug engine
Does anyone have any tips or tricks to changing these plugs without removing the intake manifold?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-19-2007, 10:59 PM
Meter Man's Avatar
Meter Man is starting off with a positive reputation.
Smile Plug changes are tough for me too!
Well, You do not have to remove the Intake Manifold (at least not on my 90 Ranger), but it is very difficult to get at two of the plugs that are under the manifold. I usually end up using a Universal joint between the Spark Plug Socket and the 10" extension that is attached to the ratchet. Some Spark Plug Sockets have a Universal Joint Attached to them (I like these better).
Anyhow, If it is like mine you may need a pair of long Needlenose pliers (maybe 12" length) to reach in and remove the wires from the plugs. Be careful and try to rotate the wire on the plug to break it free, then carefully pull on the wire as you rotate it (that reminds me to buy a good spark plug wire removal tool). I also remove the alternator; this allows me to access the front plug and gives me a bit more room to see what I'm doing.
Using the ratchet & socket, I reach in between the Intake Manifold runners to remove one of the difficult plugs (3rd one back from the front). To reach the furthest plug I remove the pipe that connects the EGR Valve to the Exhaust; I do this at the Exhaust because I cannot get a wrench to turn at the EGR Valve End of things.
Then I unplug anything that is in the way of the EGR Valve and I remove both EGR Valve Bolts and the valve from the engine. This allows me a little space between the engine & firewall so that I can get the back plug out. This all takes me alot of time (I usually spend 3-4 hours changing plugs & sometimes wires too), one of my problems is that I have fat fingers (about size 16 ring).
You may need to attach a short piece of vacuum hose to end of the new plug before installing. This allows you to more easily feed the plug into the hole. Rotate the vacuum hose to start the plug into the hole and avoid crossthreading.
It is pretty difficult for me to change plugs, but I always manage to get it done.
Perhaps some better suggestions or advice can be obtained from others on this excellent website.
Best of luck to you
Gary
  #3 (permalink)
Old 08-19-2007, 01:53 PM
big blue 95 is starting off with a positive reputation.
One thing i figured out when putting the wires back on is that you can guide the wires from underneath the manifold itself. Just like gary said extensions long pliers are your best friend.
  #4 (permalink)
Old 08-31-2007, 04:28 PM
Geimer is starting off with a positive reputation.
Plug change on 8 plug 2.3l four cylinder
Yep those right side plugs are difficult. I used a piece of twine and made a slip knot and worked around the rubber plug boots and then gave it a pull to get the boots off of the plugs. I did this several times while both changing plugs and wires. ALso used the u-joint type of extensions with two other long extensions to get to the plug socket around the plug.
Don't forget to blow out the area around the plugs with compressed air first to remove gravel and dirt etc before taking out the plugs. You don't want that nasty stuff going down the plug hole.
I've always brushed a little hi-temp anti seize compond on the threads of the new plugs before re-inserting them. I stripped the threads out of an aluminum head years back so I've done that ever since.
Good luck
  #5 (permalink)
Old 11-24-2007, 04:13 AM
83bigbroncoguy is starting off with a positive reputation.
The easiest way I've found to change the plugs themselves is a 3" extension and a 6" extension on poopsite ends of a swivel (u-joint)...It takes a little effort but you'll get 'em out.
__________________
'95 Ranger - 2.3L, 5 spd. Almost 200k on the odometer. It says something when you can still drive your truck after a TREE falls on it in a storm.
Drive it until the wheels fall off...Then put new wheels on it.
  #6 (permalink)
Old 11-27-2007, 04:41 PM
68 351 bronc is starting off with a positive reputation.
Quote:
I have a 6" extension but no poopsite . What should I do??
__________________
2001 F250 V-10 auto XLT 4X4
68 Bronco GT40 351w, NV3550 5sp, sweet!!!
  #7 (permalink)
Old 11-27-2007, 08:59 PM
DesertStorm's Avatar
DesertStorm is gaining momentum as a positive member of FTE.DesertStorm is gaining momentum as a positive member of FTE.
you need about 4-6 beers and no regard for the skin on your knuckles.
__________________
Member of South Carolina Mudboggers Association
94 Ranger 2wd sittin on 33x12.50's.
93 Ranger 4wd sittin on 39's.
Proud owner of 2008 F-150 4X4!!!!!!!!
Lots of scratches and one bent crossmember already with only 1300 on the odo.
p.s. Dont tell anyone but I use it like a truck is supposed to be used.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
