Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-18-2007, 03:20 PM
dverkest's Avatar
dverkest is starting off with a positive reputation.
Edelbrock Performer 5.0 EFI truck manifold
I have a 1995 F150 2wd, ext.cab, 5.0 auto with 3.55LS rear end. I’m looking to get some more power and torque out of it, but still keep it CA smog legal. I notice Summit sell the “Edelbrock Performer 5.0 EFI truck manifold” for $549 and claims it adds an extra 37 HP to your top end. Has anyone out there done this with their 302’s? If so was it worth the money?
Even after replacing the exhaust and Air cleaner housing to a more free flowing system, the truck is still a little wimpy for me. I realize the 302 is not a stroker so I’m not sure if I should put any money into a 5.0 or just upgrade to a 351.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-18-2007, 04:46 PM
Torque1st's Avatar
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
The 5.0L forum will probably have users with that setup.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
Eric
Tips & Tricks FAQ for 335 Series Motors
73-79 FAQ & Info
Garage Forum FAQ
For more info use PM.
  #3 (permalink)
Old 07-19-2007, 08:52 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Waste of money, the factory intake flows more than enough air for a 302. The only way to boost low rpm TQ on a 302 is with long tube headers. The next best thing(meaning biggest power boost and most cost effective) you can do for more power is upgrade the cam. The Comp Cams 35-349-8 is a healthy step up from the factory roller cam.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #4 (permalink)
Old 07-21-2007, 10:49 AM
TheTowingCowboy's Avatar
TheTowingCowboy is starting off with a positive reputation.
You can buy a Lightning 351 engine on ebay for 2500 or a little more, that includes shiping. The engine usually have all the stuff, and have under 100000 miles on them.
__________________
Cracked
Heads and
Extensive
Valve
Rattle
On
Long
Extended
Trips
It isn't bragging if you can back it up!
Does not play well with others (cause most people have a problem with losing)
  #5 (permalink)
Old 04-17-2008, 08:56 PM
Zamobafood's Avatar
Zamobafood is starting off with a positive reputation.
It not the 5.0L version but I do have the 5.8L Edelbrock Performer EFI intake and it gives a noticeable power gains in the lower RPM range. It looks great, provides better access to the passenger side area under the intake. I don't have the sources to back it up but I've heard the factory intakes have a tendency to starve the front intakes of air. If you have money burning a hole in your pocket it may be worth it. However, the 5.0L version has been discontinued to my knowledge and since you have a 5.0L anyways Mustang mods are the way to go. If your truck is mass airflow thats a big plus. If its speed density you are in a hole like myself and the conversion to mass airflow will give the biggest improvements.
Plus, with my K&N generation II air intake installed with the Edelbrock intake I am running on the lean side and increased wind noise at low rpms is very noticeable. The intake sit higher up than the stock but it won't (at least for me) create any hood clearance problems.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
