Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-18-2007, 03:05 PM
COLEnMICHAELS66 COLEnMICHAELS66 is offline
Garage is empty, add now
COLEnMICHAELS66 is starting off with a positive reputation.
1st fillup with E85
well i just filled up my 02 Chebby S10 with E85 yesterday, its amost 50 cents a gallon cheaper than regular gas. is there anything special i need to do to the truck to tolerate the new fuel. i know it says on the gas tank door that i should not use any additives when running E85. anything else i should know?
  #2 (permalink)
Old 07-21-2007, 05:31 PM
390fe 390fe is offline
1970 Ford F-100
390fe is starting off with a positive reputation.
Jason Kendrick
Just enjoy!
__________________
Jason Kendrick
'93 F350 Crewcab 5.8L
'70 F100 Custom 390/C6 (temporarily retired)
'93 Mercury Topaz 2.3L
'99 Ford Windstar SEL (bad transmission - For sale)
  #3 (permalink)
Old 07-21-2007, 09:11 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.
If your vehicle is a flex fuel vehicle. Enjoy !
If not- check the instruction manual for fuels. using E85 in a non flex fuel vehicle will damage the fuel system.
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #4 (permalink)
Old 07-21-2007, 09:52 PM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
E85 shouldn't hurt a 02 vehicle, even if it's a Chebby.
Of course, if it's not a flex fuel vehicle, significant mpg drop may happen.
  #5 (permalink)
Old 08-04-2007, 12:14 AM
christcorp's Avatar
christcorp christcorp is offline
christcorp is gaining momentum as a positive member of FTE.
Yes, enjoy! That is until you notice that your gas mileage has gone down per tankful compared to 87 octane fuel. (If you ever monitored it before). And because your mileage has gone down, you will need MORE of the E85 gas to get you the same distance. And if you figure it all out, you will find that it probably cost you a couple dollars MORE per tank to go the same distance. But hey, enjoy it.
At a $0.50 a gallon different in price, you are looking at approximately a 20% savings. So that means you can't go down more than about 20% in mileage. Anything more than that, and it will cost you more per gallon to use ethanol. Remember, pure ethanol is about 30% less efficient in producing energy as gasoline is. Because you aren't burning pure ethanol, it's 85% and the other 15% is gasoline, the ethanol is actually only about 25% less efficient. But I am giving the benefit of the doubt and going with 20%. Good luck. Later... Mike....
__________________
The Ford Family:
2000 Ford Focus - 143,000 miles
1994 Ford Explorer (4.0l V6) - 114.000 miles
1994 Ford F250 (460 V8) - 65,100 miles
1966 Ford Mustang (289 V8) - 141,200 miles
"Born Wild; Raised Proud"
  #6 (permalink)
Old 08-04-2007, 07:30 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
The efficiency of producing energy (work) from fuel is in the mechanics of the engine and of the tune. Ethanol has less stored energy than gasoline and requires a different air/fuel ratio to burn properly. These engines are getting the same percentage of energy from the fuel, the only problem is, there's less energy available, so more of it has to be burned to make the same (or more) power. Come back when there are engines designed to use ethanol efficiently and we'll see where we are then in terms of fuel economy/cost, and environmental impact. There's no question that flex fuel vehicles are a compromise all the way around.
__________________
Eric
'87 F150 302 ZF 5 speed 4x2
  #7 (permalink)
Old 08-04-2007, 01:29 PM
utah4X4 utah4X4 is offline
utah4X4 is starting off with a positive reputation.
http://e85vehicles.com/e85/index.php
Try going to that site and telling everyone there that they are losing power, wasting fuel, wasting money, losing milage, etc., etc. I know its not it neutral site, but at least the people there have actually ran the fuel and are not just going by what they heard from the news and what they read on internet message boards.
  #8 (permalink)
Old 08-04-2007, 05:16 PM
76supercab2's Avatar
76supercab2 76supercab2 is offline
76supercab2 has a good reputation on FTE.76supercab2 has a good reputation on FTE.76supercab2 has a good reputation on FTE.
Why don't YOU try doing a search on Christcorp's recent posts. He IS talking from his own experience. He DID experience a drop of approx 20% in mileage and when you do the math, a fifty cent savings per gallon at the pump doesn't cover the loss in efficiency.
Also, if you look in the 'You Guys Don't Get It' thread, you'll see WhiteShadow also posted similar results. Yet for some reason, he's tickled pink to be spending more to get to his destinations.
Ethanol is a scam foisted upon the American people that at best will not pan out to work in the long run, at worst, it will cripple this country.
Seriously Cole, do an indepth analysis to see if you are really saving any money overall. You need to calculate the cost for you to go 1000 miles for the two fuels to know if your saving money. Price at the pump is only part of the story.
  #9 (permalink)
Old 08-04-2007, 10:07 PM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 has a good reputation on FTE.Dean88 has a good reputation on FTE.
If E85 came out after all of the mpg drop, a couple of dollars more expensive, I would use it in a heartbeat, because Ethanol is produced by corn grown from AMERICAN farmers, converted in AMERICAN plants, so more money goes into AMERICAN pockets.
__________________
1999 F250 7.3 ZF6 4x4 3.73's 200k miles
1997 F250 7.3 ZF5 2wd 4.10 430K miles
Dr. Ron Paul 2012!!
  #10 (permalink)
Old 08-04-2007, 11:36 PM
I have put up to 25% ethanol in my car and when I did that I noticed no difference in milage People on that forum are using E85, some with less than a 10% drop in milage. Nearly all with less than a 20% drop There could would be very little to no difference in milage if people would build more engines optimized for E85.(I realize that is not practical until more stations come online, however.)
And by the way, How could you lose 10% of your milage when the fuel is only 10% ethanol. That would mean the ethanol had NO energy. Either that or something is wrong with the car to not adjust correctly.
I also agree that the money for ethanol is going to a much better place than the money we spend on gas/oil.
  #11 (permalink)
Old 08-05-2007, 01:20 PM
christcorp's Avatar
There are a lot of debate going on about ethanol vs gasoline and efficiency. Let me just say this 1 way. A vehicle made for gasoline is potentially the most efficient when using gasoline. A vehicle made for ethanol is most efficient when using ethanol. Flex fuel vehicles or fuels that try and "MIX" 2 different fuels to find a compromise, are the least efficient of all forms.
So, if people are going to go with ethanol, then go 100%. Forget this FLEX and compromise crap. At least I could then respect the position. I wouldn't agree with it, but I would respect it. There is no reason in the world to have E10 and E85 fuel. The only reason for such a compromise is for political reasons. The reason for E10 mandates in the first place is because companies like Archer Daniels Midland have lobbied the politicians to force it on the consumer so that they can make more money. It's not the government doing it because it's the right thing to do. It's the politically correct thing to do to the voters, and financially correct thing to do for the lobbiests.
When Henry Ford started producing the automobile, as well as accounts in Europe and their car crusade, grain alcohol is what was used as fuel. Obviously they didn't have a major need for pretroleum being the combustion engine was just being invented. So, the question begs to be asked; If you already have a fuel source that you are familiar with. That's you've been distilling for hundreds of years. That you know what it's capabile of doing. Why in the world would you change from using it to using gasoline? Why not improve on the engine that is newer and still being developed instead of changing the fuel source? And why now, would we be going "BACKWARDS" in technology back to a fuel source that was originally used. It was obviously easier for Ford and the other people working on the combustion engine to "MAKE" grain alcohol (Ethanol) then it was to drill and refine pertroleum. Even if the use of petroleum for other uses was becoming the norm, if using grain alcohol was better, cheaper, more efficient, and so on, why would you leave it?
No. You really have to look at ethanol beyond an emotional state. The whole; "It supports the USA and farmer" is admirable, albeit VERY MISGUIDED. Very little money goes to supporting the local farmer. You think it does, but it doesn't. And the majority of that money is in subsidies from the tax payer.
It isn't possible to grow enough corn, beet, cane, switch, etc... to produce the amount of ethanol required to support our needs. Our country doesn't have that much land or water to do it. Ethanol is not the right answer. It's not even the right direction. It's not even a band-aid until something better comes along. If all those subsidies were given instead to ALL the universities in the country, to be used towards developing alternative sources of energy, we would have much better returns on our investments. Unfortunately, the American tax payer and the Universities aren't the lobbiests that get the government's attention. Anyway, feel good and be happy. Later.... Mike.....
P.S. The question was asked; " And by the way, How could you lose 10% of your milage when the fuel is only 10% ethanol. That would mean the ethanol had NO energy. Either that or something is wrong with the car to not adjust correctly." My answer is; take a gallon of 87 gasoline, make 20% of it WATER. Then, run it in your car and see what happens. If you think it will be exactly 20% less gas mileage, then go for it. As I wrote above. 100% ethanol in an engine designed for it, is one thing. 100% gasoline in an engine designed for it, is also one thing. Flex-fuels and mixing ethanol into gasoline engines is something different.
__________________
The Ford Family:
  #12 (permalink)
Old 08-10-2007, 05:31 PM
EPNCSU2006's Avatar
I definitely agree with you there, but it doesn't have to be optimized for 100% ethanol. Even optimized for E85 would make a substantial difference. Plus, E100 would suffer terribly in cold starts in cold weather. The 15% gasoline aids in cold-weather performance and general driveability.
That's a terrible comparison, because water is not combustible. Ethanol burns! From an engineering and thermodynamic standpoint, I have to side with the person who asked the question to start with.
__________________
Eric
  #13 (permalink)
Old 08-12-2007, 09:17 PM
christcorp's Avatar
You are correct; water is not combustable. Until turned to steam. By the previous poster was making the point, in a round about way, that if the fuel was ONLY 10% ethanol, that it is impossible for the MPG to be reduced past 10%. If so, then that meant that the ethanol had no efficiency. My point was that as individual components, chemicals react a certain way. When combined, they can react totally different. No different than adding equal parts of hydrogen and oxygen and coming out with hydrogenPeroxide. Add twice as much oxygen, and you get water. Yet hydrogen can be used as a fuel, so how if water isn't combustable.
Point being, 10% ethanol in gasoline CAN reduce the efficiency MORE than 10%. Later... Mike....
__________________
The Ford Family:
  #14 (permalink)
Old 08-13-2007, 08:49 AM
EPNCSU2006's Avatar
Last I checked, steam was just as non-combustible as water. Ethanol contains approximately 70% the amount of energy as gasoline, so from a pure efficiency standpoint (energy out/energy in) it is impossible to lose more than 10% efficiency with a 10% ethanol/90% gasoline mixture (E10 has 97% of the energy of 100% gasoline). As far as gas mileage is concerned, that depends on the individual engine and tune.
I worked as engine team leader for a Formula SAE student race team for the past three years, last year switching to E85. Raw fuel economy was 16% less with E85 when compared to 100 octane gasoline. Same turbo, same engine, same compression ratio, 13 more foot-pounds and a couple more horsepower than with 100 octane.
Unless driving style changes, I don't see how 3% less energy can cause more than a 10% change in miles per gallon, especially since the engine itself is getting the same percentage of energy out of the fuel as it did with straight gasoline.
__________________
Eric
  #15 (permalink)
Old 08-13-2007, 11:00 AM
christcorp's Avatar
sorry about the "Steam" combustable statement. I meant to imply that water could not produce the energy similar to gasoline, in the sense of moving pistons, until it was converted to steam. You are totally correct that it's not combustable. Same with components of hydrogen and oxygen, but as H2O (Water) it isn't combustable. Later... Mike....
__________________
The Ford Family:
Tags
2002, e85, explorer, fill, flex, ford, fuel, lose, mileage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
