Boss 302 Heads - Ford Truck Enthusiasts Forums
Boss 302 Heads
Old 11-18-2001, 06:23 PM
GrimReaper GrimReaper is offline
GrimReaper is starting off with a positive reputation.
Boss 302 Heads
I'm looking for Boss 302 Heads. Are there any repro. companies? Any one got any? All input is thanked.
Old 11-18-2001, 08:59 PM
stryder's Avatar
stryder stryder is offline
stryder has a good reputation on FTE.stryder has a good reputation on FTE.stryder has a good reputation on FTE.
Boss 302 Heads
Try http://www.vintage-mustang.com Put a post in the parts wanted section of the classifieds. Or try http://www.ebaymotors.com
Styrder
Old 11-24-2001, 03:25 AM
dinosaurfan dinosaurfan is offline
dinosaurfan is gaining momentum as a positive member of FTE.
Boss 302 Heads
Grim, what on earth do you want those for ? I have another idea if you would consider using 351M/400 heads....... let us know what you have in mind. DF
Old 11-24-2001, 02:24 PM
cobrajet cobrajet is offline
cobrajet is starting off with a positive reputation.
Boss 302 Heads
go to your local book store and buy Hemmings Motor News. this big book has everything in it for the restorer, all kind of hot rods for sale and etc.. they have all kinds of ford parts for sale. you might be able to find a nice pair for $$. also try Perogie Enterprises at 1-609-448-1684. they have several pairs of heads in stock some bare and some complete, check with them for prices. i don't have their e-mail address right off hand. CJ.........
Old 11-26-2001, 12:10 PM
Rosati's Avatar
Rosati Rosati is offline
Rosati is starting off with a positive reputation.
Boss 302 Heads
Old 11-28-2001, 12:03 AM
bsprowl bsprowl is offline
bsprowl is starting off with a positive reputation.
Boss 302 Heads
The original (1969) Boss 302 head and the 351C 4BBL head are very similar and may even have the same casting number. They even had the same chamber volume. The only difference was the size of the intake valve 2.225 for the Boss and 2.19 for the standard 351C 4 BBL. ANd the 351C could be fitted with the larger valve.
Old 11-29-2001, 05:41 PM
Boss 302 Heads
I found a Ford performance book, from 1970 something or other, at my house, that shows you how to basically turn a regular 302 into a Boss. It calls for either the Boss heads, or the 351C heads that have larger valves and have some modifications done to them.
Old 11-29-2001, 09:43 PM
shazam shazam is offline
shazam is starting off with a positive reputation.
Boss 302 Heads
Your basic difference between the Boss 302 and 351 4V heads is the water passage.On the boss head there in the intake Crossover area, and the 351 4V there in the Block area. You can use the 351 4V heads on the 302 but you have to block off the water passage for the block and drill a hole for the intake water passage.Or you can buy a set of Boss 302 heads which I have an extra 1970 set of.
Old 11-29-2001, 10:39 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Boss 302 Heads
A guy told me, when it was all said and done, you are performance ahead and cheaper to buy one of the new aluminum aftermarket heads for a 302. The special intake manifold for the cleveland swap is about 400.00 last time I checked. Then you have to hassle with special alt brackets and cleveland exhaust manifolds or headers.
Old 11-30-2001, 04:24 PM
nickc84 nickc84 is offline
nickc84 is starting off with a positive reputation.
Boss 302 Heads
Hey Guys,
You cannot change a regular 302 into a boss 302 by simply changing the heads. The boss 302 had 4-bolt mains and had a high nickel content in it. While the regular 302's are a dime a dozen, to find a true boss 302 is a wonderful find. I'd love to have my hands on those heads or the block.
Nick
Stock to Boss?? hotrodkid05 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 15 08-08-2005 08:13 PM
Difference between 429 Cobra & 429 Boss denisontexas Performance & General Engine Building 13 05-25-2004 03:52 PM
351M heads to Boss 302 heads fastermustang Wisconsin Chapter 1 07-20-2003 12:03 AM
Boss 302 piston questions stormr Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 02-11-2002 12:05 PM
boss 302 elsmith Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 06-11-2000 12:01 AM
Tags
302, 302c, 351c, boss, heads, identify, passages, sale, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
