4x4 hubs....auto & lock
Welcome to FTE, mrpjr!
When in 2 wheel drive, the front hubs allow the front wheels to spin without having to spin the front axles and front driveshaft. This saves fuel, makes the truck a little quieter and supposedly saves on drivetrain wear.
When you put the truck in 4H or 4L and the hubs are in AUTO, the hubs lock the wheels to the axles. The transfer case sends part of the torque to the front axle, which turns the wheels.
If the hubs fail and you need 4 wheels drive, you move the hub selector from AUTO to LOCK, which manually locks the hubs to the axle. YOU ARE NOT IN 4 WHEEL DRIVE AT THIS POINT. It doesn't hurt anything to drive the truck on dry pavement. You would still need to put the selector in 4H or 4L to be in 4 wheel drive.
Originally Posted by f350rebel
so they should always be in auto unless they fail correct.....then when you want 4x4 you just turn the **** on the fly
Bill
Originally Posted by mrpjr
thank you. im confused...so if i go to 4 wheel high or low i don't need to change from auto to lock?
Bill
Welcome to the site.
This along with many other things are covered in your owner's guide. It is a very good idea to take an hour or so of your time to read through it. If your truck didn't come with one you can enter your year and model at the following website and download one for free.
http://www.motorcraftservice.com/vdi...&menuIndex1=18
Also the first thread in this forum is the Tech Folder. By following the links in it you can answer a lot of the other questions that you will soon be asking.
one of my hubs was in the auto position and one was in the lock position did this cause any damage to my 4x4.......
Seriously, it isn't good to do this. You're creating more friction drag on one side of your truck, which might create an unsafe pull in the steering.
[QUOTE=redford]No, but it may cause uneven tire wear, premature baldness and halitosis.
QUOTE]
Danged now I know where the hair went.
It might also cause a slight drift when driving to the side with the locked hub due to drag of the axle and gear drag.
There is a note in the manual about not using 4WD on dry paved surfaces.
QUOTE]
Since I have manual hubs I lock my front hubs if I think I might need 4 wheel drive. (Snow or off road). That way, I don't have to crawl out of the truck later to engage them, I just put the transfer case in 4H and off I go.
