How To Remove Pulley On Power Steering Pump
Old 01-17-2002, 05:48 PM
JJH's Avatar
JJH
JJH is offline
How is the best way to remove the pulley on the power steering pump on a 302 serpentine set up. It has a allen wrench slot inside of the shaft. Which way does it turn? Is it left hand or standard?
Old 01-17-2002, 10:42 PM
slikness's Avatar
slikness
slikness is offline
I believe the pulley is pressed on and you need a special took (not very expensive) to get it off. The last power steering pump I purchased had this tool included in the pump.
Old 01-18-2002, 10:03 AM
beartracks's Avatar
beartracks
beartracks is offline
Those things are a pain. You need a good puller designed for the task not a three arm unit. Some parts places will pull them for you.
Bear Tracks
Old 01-18-2002, 11:28 AM
JJH's Avatar
JJH
JJH is offline
Yep! I checked with the auto parts machine shop that has done a lot of work for me and a $10 bill will get the pulley pressed on and off!
A lot cheaper than me tearing up the pulley trying to get it off.
Thanks for your advise.
Jerry
Old 01-19-2002, 03:38 PM
CRJ900's Avatar
CRJ900
CRJ900 is offline
i know auto zone does it for free
Old 01-19-2002, 09:25 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
pete60hill
06-27-2014 12:37 AM
straightsixer
03-09-2013 12:38 PM
Jaaaaaaackman
03-10-2012 08:53 PM
SparkyRnD
27
11-02-2010 10:50 PM
skyjacker10
01-10-2010 10:25 PM
Quick Reply: How To Remove Pulley On Power Steering Pump
