How To Remove Pulley On Power Steering Pump - Ford Truck Enthusiasts Forums
Old 01-17-2002, 06:48 PM
JJH JJH is offline
JJH is starting off with a positive reputation.
How is the best way to remove the pulley on the power steering pump on a 302 serpentine set up. It has a allen wrench slot inside of the shaft. Which way does it turn? Is it left hand or standard?
Old 01-17-2002, 11:42 PM
slikness's Avatar
slikness slikness is offline
slikness is starting off with a positive reputation.
I believe the pulley is pressed on and you need a special took (not very expensive) to get it off. The last power steering pump I purchased had this tool included in the pump.
Old 01-18-2002, 11:03 AM
beartracks's Avatar
beartracks beartracks is offline
beartracks is starting off with a positive reputation.
Those things are a pain. You need a good puller designed for the task not a three arm unit. Some parts places will pull them for you.
Bear Tracks
Old 01-18-2002, 12:28 PM
JJH JJH is offline
Yep! I checked with the auto parts machine shop that has done a lot of work for me and a $10 bill will get the pulley pressed on and off!
A lot cheaper than me tearing up the pulley trying to get it off.
Thanks for your advise.
Jerry
Old 01-19-2002, 04:38 PM
CRJ900 CRJ900 is offline
CRJ900 is starting off with a positive reputation.
i know auto zone does it for free
Old 01-19-2002, 10:25 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Power Steering pump pully removal and install pete60hill 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-27-2014 01:37 AM
'93' F150 Powersteering pulley removal straightsixer 1987 - 1996 F150 & Larger F-Series Trucks 5 03-09-2013 01:38 PM
Vacuum pump pulley Jaaaaaaackman 1994.5 - 1997 7.3L Power Stroke Diesel 11 03-10-2012 09:53 PM
Power Steering 351w, anyone have a picture? SparkyRnD 1973 - 1979 F-100 & Larger F-Series Trucks 27 11-02-2010 11:50 PM
power steering pump pulley skyjacker10 1994.5 - 1997 7.3L Power Stroke Diesel 9 01-10-2010 11:25 PM
Tags
1994, diesel, f150, f250, ford, power, pull, pulley, pully, pump, remove, removing, sreering, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
