conversion or lift?
Is your truck a 2wd?
Find a suspension system and do the whole suspension lift, and a L/S rear end sounds good.
Skyjacker has 4inch 2wd suspension systems also check Ebay for deals.
A locker may also work in the rear diff, if you go to larger tires, you should consider regearing too.
lildrummer420
08-28-2011 12:49 AM
