351w vs 360 fe - Ford Truck Enthusiasts Forums
351w vs 360 fe
Old 07-15-2007, 10:00 PM
mattri mattri is offline
mattri is starting off with a positive reputation.
351w vs 360 fe
Have a 69 f100 2wd with a 360 fe. Truck is going to be a daily driver, no heavy towing. Looking to either build up the 360 a little, maybe swap in 390 crank rods, 4v intake and carb, mild cam, headers and elec ignition.
Or swap in a 351w, same mild build, stock heads.
Not looking for huge power numbers, just want something that will get out of its own way, be a good driver and not kill me on gas.
Looking at the windsor because it's close in cubes, lighter and can bolt a 5spd up pretty easy. Any suggestions, ideas? Thank, Matt.
Old 07-16-2007, 12:05 AM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
You will find a wider variety of aftermarket parts and accessories with a 351w.
Old 07-16-2007, 12:18 AM
Mtthwvn73's Avatar
Mtthwvn73 Mtthwvn73 is offline
Mtthwvn73 is starting off with a positive reputation.
I'd say find you a 390. You already have the tranny (An FE bellhousing won't bolt up to a smallblock). You'll be able to spend the money on the motor, and not have to worry about messing with a different tranny, probably having to change driveshafts, different mounts, ect. You can keep the tranny, and still make a good bit of power. Rebuild a 390 and get the power package from Edelbrock, that should really get that truck moving.
Matt
Old 07-16-2007, 08:34 AM
Thanks for the replies. I deffinetly want to swap trannys, looking for a 5spd, not the granny 4spd I have now.
Old 07-16-2007, 03:59 PM
HemiEater's Avatar
HemiEater HemiEater is offline
HemiEater is starting off with a positive reputation.
then go with the 351W other wise do a 390 like mtthwvn73 said.
Old 07-16-2007, 06:55 PM
Red69 Red69 is offline
Red69 is starting off with a positive reputation.
The 351W will take a different set of engine mount towers and you will have trouble finding an exhaust that works in that model truck.
Old 07-16-2007, 11:26 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
No problem with exhaust when using manifolds. Any exhaust shop can make a system from the manifolds back. They did on my 63 F100 with a 351W. You will need 302 motor mount towers. Pretty common on those trucks.
Old 07-17-2007, 06:04 PM
I have a set of stock manifolds and the outlet is about 2 inches away and pointing straight at the firewall when I tried them on my 69..
Intake for TBI FE nkf Fuel Injection, Carburetion & Fuel System 1 12-06-2016 08:51 PM
360 FE and 351m 400 darkpurp1e 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-10-2012 08:18 PM
351w vs 360 daily driver mattri FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 07-16-2007 05:51 PM
351W engine swap popeye69 1967 - 1972 F-100 & Larger F-Series Trucks 8 02-01-2005 12:00 PM
360 or 351W...Which is worth building? popeye69 1967 - 1972 F-100 & Larger F-Series Trucks 5 07-30-2003 11:32 AM
Tags
351, 360, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
