Check Engine Light Gone Now?
Old 07-15-2007, 11:03 AM
duggyb's Avatar
duggyb
duggyb is offline
Well i have had the Check Engine Light on since i bought the truck back in April..with System Lean Bank 1 and System Lean Bank 3 codes.....which i assume is becuase of my retapped O2 sensors and no cats.....but i am just wondering what would have caused it to go out?...
could it be the tempature change?...becuase it got ALOT hotter here than it used to be back when i got the truck.
THNX
Duggy
Old 07-15-2007, 04:06 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Most likely, you have a vacuum leak that has lessened with the hot weather. It is unlikely to be related to the O2 sensors and certainly is unrelated to the lack of cats (that causes different fault codes)
The light went out because the self-test didn't fail the last time it ran. It will be back. The computer has stored the fault code in memory (unless reset).
Steve
Old 07-15-2007, 04:52 PM
ncranchero's Avatar
ncranchero
ncranchero is offline
Does the check engine indicator light still light up when you switch the truck to "ON"? If not, maybe your bulb finally wore out .
Old 07-16-2007, 01:48 PM
duggyb's Avatar
duggyb
duggyb is offline
no the bulb still works...i went and checked.
but i did forget to mention in this post that i cleaned my MAF in between that...
and after reading that large post before titled "Maf".....i am pretty sure that why it went out...
so my MAF must have been setting it off.
THNX
Duggy
FordMan10
1997 - 2003 F150
08-30-2010 12:22 AM
mondoogies
1997-2006 Expedition & Navigator
19
09-10-2008 08:46 PM
50th ann
1997 - 2003 F150
06-23-2008 03:54 AM
78bigbronco
1997 - 2003 F150
10-18-2005 08:59 AM
Quick Reply: Check Engine Light Gone Now?
