Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Illinois Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Illinois Chapter Join Chapter Leader: KOESTNER
  #1 (permalink)
Old 07-15-2007, 10:25 AM
illinois4by's Avatar
illinois4by illinois4by is offline
Garage is empty, add now
illinois4by is starting off with a positive reputation.
Axle travel
My dana44 axles have a bit of travel (in and out that is) how much travel should i have if any at all? I do get a rattle in the front end. Ive checked and everything is tight but the axles. I was wondering if the c-clips in my diff came out? Any ideas. Oh and Im experimenting with my 300-6 if all goes well i should get around 500hp out of it by theory. Ill keep you updated.
__________________
90 F-150 4x4 6inch suspension 35x12.50 Cooper STT (Work in progress)
  #2 (permalink)
Old 08-02-2007, 11:49 AM
amish77's Avatar
amish77 amish77 is offline
amish77 is starting off with a positive reputation.
If the clips come out then you're fubar. The axles will slide out of the tubes. There's probably something else in the pumpkins that's a little loose.
__________________
300 CI bored .030 over with a 240 head (303 CI). Clifford valves, Comp Roller Rockers, crane cam, Offy intake, true dual headers, x-pipe, pretty spicy.
  #3 (permalink)
Old 08-02-2007, 01:46 PM
Rev Den Rev Den is offline
Rev Den is starting off with a positive reputation.
How much travel?
more then a "feel" and I would pull the cover and check the center pin for wear.
Rev
__________________
Want to support our troops? Stop buying those stupid yellow ribbons and donate to the USO!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
