How to remove rear door panel? - Ford Truck Enthusiasts Forums
Old 07-15-2007, 08:44 AM
BlackFX4Screw BlackFX4Screw is offline
BlackFX4Screw is starting off with a positive reputation.
Need to fix a rattle. Before I tear something up anyone got some tips?
Old 07-15-2007, 08:48 AM
NASSTY's Avatar
NASSTY NASSTY is offline
NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.
Old 07-15-2007, 11:16 AM
black04lariat's Avatar
black04lariat black04lariat is offline
black04lariat is starting off with a positive reputation.
nassty- yours are for the front door panel i believe. he needs the rear of a screw.
i know how to remove the rears of the scab but that really doesnt help you out much and cannot remember off the top of my head how to remove the screw rears.
Old 07-15-2007, 11:20 AM
I did not write this nor do I take credit for it. I found it on another forum.
1) Remove the trim peice at rear edge of window. Pull and it comes off.
2) Remove screw exposed by removal of trim peice, along with 2 screws at bottom of door panel.
3) Remove small access panel inside door handle, remove 2 screws exposed.
4) Remove panel that houses the power window switch, just pops off, remove bolt exposed inside (kind of tricky angle to get this one, but it can be done)
After removal of all screws, lift door panel up and out and it should come right off.
Old 07-15-2007, 11:24 AM
NASSTY's Avatar
Doh
Old 07-15-2007, 02:33 PM
spiggy769 spiggy769 is offline
spiggy769 is starting off with a positive reputation.
First remove the Rear window panel cover from the door(one on each side of the window)...starting from the top and working your way down...It is held in by clips so dont be afraid to give it a little force. This will expose 2 screws.
  • Dunno if you have Power windows in the rear or not but if ya do ya have to pry up the controller on the armrest and look for a screw...If ya dont look under the armrest.
  • Remove the screw(s) at the bottom of the door panel
  • Pry open the little cover on the door handle exposing 2 more screws....remove these and move the handle away from the door.
  • Grab the armrest and lift up and out
Tags
1997, 2000, 2002, 2007, 2008, back, door, escape, explorer, f150, ford, panel, rear, remove, removing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
