Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 07-15-2007, 06:34 AM
rascal1 rascal1 is offline
Garage is empty, add now
rascal1 is starting off with a positive reputation.
Auto Locks Make it STOP!!!!!!
I have a 2002 f350 psd any one have any ideas how to make the auto lock when you start driving stop. I find this very annoying i get out and can't get anything out of any door without remembering to unloock the doors . I think my dogs are annoyed too! Thanks
  #2 (permalink)
Old 07-15-2007, 08:32 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
Is there anything in the owner's manual about it?
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #3 (permalink)
Old 07-15-2007, 09:33 AM
gunnertom's Avatar
gunnertom gunnertom is offline
gunnertom is starting off with a positive reputation.
Yes Its in the owners manual.If you don't have one pm me an i'll go out an get mine
__________________
Tom,Okeechobee FL
2002 F350 2wd cc drw 7.3 auto, ccv mod, foil delete, 6637, t/c mod on a dimmer switch, ,Single stack,,dptunes, H idle,60 tow,80 econo,100 perf,120 race, gauges.recon smoked cab lights, ITP OBA.Sliverstar ultras.2 inch leveling kit.Riffraffs frx,hpx.
  #4 (permalink)
Old 07-15-2007, 09:37 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
Yep. RTFM. It's in there... I wanted mine to lock, so I turned it back on after the previous owner apparently turned it off...
It's on page 64 of my '02 F250 manual. But here's how to do it:
Deactivating/activating the autolock feature
Before following the procedure, make sure that the ignition is OFF and
all vehicle doors are closed.
You must complete steps 1-7 within 30 seconds or the procedure will
have to be repeated. If the procedure needs to be repeated, you must
wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
__________________
  #5 (permalink)
Old 07-15-2007, 09:39 AM
amiller93's Avatar
amiller93 amiller93 is offline
amiller93 has a good reputation on FTE.amiller93 has a good reputation on FTE.
There is a convoluted way to disable this, something like turn the key on 3 times and then hit the door lock button several times but I cant find the procedure now. Might want to check with the dealer and see if they have the procedure they can print out for you.
Edit: Yep Izzy Beat me to it
  #6 (permalink)
Old 07-15-2007, 09:41 AM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
was reading on here somewhere in the last couple days about them but think it was the type with buttons on the door
guess 2000's didn't have them but know they are a pain
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install, DooDad???=(dfuser ram air)
'98 Grand Cherokee, '86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #7 (permalink)
Old 07-15-2007, 10:05 AM
rbaker6336's Avatar
even the 06 uses the same procedure wonder if it would work on wifes mercury
__________________
Ray
PAA #35
  #8 (permalink)
Old 07-19-2007, 03:01 AM
Thanks!
Thanks that worked awesome I now no longer feel the need to take a hammer to all of my door locks.. Who knew there could be such valuable info in the owners manual! Well I don't have one but probably never would have looked there any way. Thanks Again I love this place!
  #9 (permalink)
Old 10-09-2008, 04:39 PM
IDPisan's Avatar
IDPisan IDPisan is offline
IDPisan is gaining momentum as a positive member of FTE.IDPisan is gaining momentum as a positive member of FTE.
Here is a great link for what you are trying to do.
2004 F-Super Duty 250-550/Excursion Workshop Manual
__________________
My two cents, Jeff
Early 99 F350 4X4 CC DRW 6spd. 6637, MKO 4" turbo back 5" straight piped exhaust 6" tip, ISSPro Gauges, Pyro, Boost, Water temp, DP Tuner Stock, 40tow, 60tow,80econo, 120race, KCM S.S. HPX line, ITP Overboost Annihilator, Auto Enginuity, GPR LED Indicator. 6.0 intercooler, CCV mod, EBPV delete,Wastegate Mod. 325,000 miles and counting.
  #10 (permalink)
Old 10-09-2008, 04:57 PM
Smokin''s Avatar
Smokin' Smokin' is offline
1999 Ford F-250
Smokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant future
Wow Jeff you sure dug up an old thread there.
I got all excited I thought amiller started posting again..
__________________
Lisa Not so Early '99 PSD long bed XLT supercab. 4" Pro Comp suspension lift, 315 BFG AT's on 17" Liquid Metal Gatlins, Casserly Stage 1 injectors, Terminator T-500 HPOP, BTS VB, Cale's tunes, 203* thermostat and billet housing, 6637 w/Pete's cover, CCV, Riffraff oil and fuel crossover, late turbo conversion - international bellowed up pipes, 4" turbo back exhaust, EBPV delete, Harley Davidson headlights. 200k club member.
  #11 (permalink)
Old 10-09-2008, 06:07 PM
IDPisan's Avatar
Doh!!!!! I was in the Superduty forum and I posted the link in an original post and,and,and Doh!
__________________
My two cents, Jeff
  #12 (permalink)
Old 11-24-2008, 01:16 PM
Benningtonr's Avatar
Benningtonr Benningtonr is offline
Benningtonr is starting off with a positive reputation.
I tried to access site listed, but it fails. Not logged in
Tags
2001, 2006, 350, auto, automatic, code, disable, door, f250, ford, ignition, lock, locks, stop, stopped, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
