Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-14-2007, 11:07 PM
Jermafenser's Avatar
Jermafenser is starting off with a positive reputation.
Spark Plugs & Idle Issues
While working on my '79 400 today, I've been trying to find its static timing. I plugged the distributor vacuum advance, and pointed the light at the marks. I can't find anything on the harmonic pulley. Not a mark or anything.
Could the marks on the pulley worn off or something? I wiped it clean as much as I could. Or is it at a different location? Or perhaps the harmonic pulley was replaced and the replacement didn't have marks on it...
I decided to pull the new spark plugs I put in a while ago as well. Most had a spot or two of dried carbon soot. Ok, it's running rich. I rebuilt the carburetor, but haven't adjusted it yet because I want to get the static timing correct first. But #4 spark plug was the worst. It was totally black and wet! I smelled it as much as I could, but it doesn't seem to be wet fuel. Could it be coolant? It smokes from that area, too. It also may explain why there is a slow coolant leak that collect on the exhaust pipes and the starter. I looked under and all freeze plugs look okay.
Also, it idles way high at 1000+ RPM. It also flucautes at 1000-1200RPM (the maximum could be read with a buddy's cheap RPM/dwell) I think it should be at 500-600RPM like most trucks of this era.
Where do I begin to address these issues? Thanks!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-14-2007, 11:33 PM
53fatfndr's Avatar
53fatfndr is gaining momentum as a positive member of FTE.53fatfndr is gaining momentum as a positive member of FTE.
Your idle speed fluctuation sounds like a vacuum leak somewhere. I'm not sure what to tell you about finding the marks on your damper, other than they can be hard to see. I end up finding my marks and marking them with some "white-out" that I have around from the old type-writer. This makes it easier to set the timing, too, as the white marks on the damper really light up with the timing light.
__________________
Branden
'53 Ford F-100 Hot Rod
'79 F-350 4X4
'94 F-150 4X4
  #3 (permalink)
Old 07-15-2007, 12:07 AM
grclark351 is starting off with a positive reputation.
it usually takes some good scrubbing to find the marks. a kitchen scrubby and carb cleaner might get you there? maybe even emery cloth to get through thick paint. you're on the front passenger side plug wire for #1, right? the idle should be a little higher than 500 but much lower than 1200, agree on the possible vac leak.
__________________
http://www.supermotors.net/vehicles/registry/10950
http://www.supermotors.net/vehicles/registry/10952
http://www.supermotors.net/vehicles/registry/16826
  #4 (permalink)
Old 07-15-2007, 10:13 AM
Guess I'll take the carburetor clean and blast it to Kingdom Come!
Will tighten down the carburetor base as it's been removed recently. If that doesn't help, the intake gasket needs attention then.
Yes, passenger side #1.
Any ideas on the other issues??
  #5 (permalink)
Old 07-15-2007, 10:29 AM
havi's Avatar
Starting over IS my style
havi is gaining momentum as a positive member of FTE.
you could spray a little starting fluid/ether at the carb base to see if it revs up to show if it's leaking or not, too.
__________________
"We are holding our own."--Ernest McSorley
The Good1948 F1: awaiting an S10 T5 tranny
The Bad1987 TC: awaiting funds for parts
And the Ugly1962 Fairlane: awaiting everything
  #6 (permalink)
Old 05-21-2008, 03:05 AM
dieselboy1988 is starting off with a positive reputation.
ok well i got a little problem of my own all the plugs are workin...but #7 when i pull it out is wet and smeels like gas...its a 78 bronco 400 in it just changed the 2 bbl to a 4bbl...and iv had nothing but problems with this truck...iv changed the wire and the plug and still the same out come still wet when i pull it out....
  #7 (permalink)
Old 05-21-2008, 07:54 AM
fmc400's Avatar
fmc400 has a very good reputation on FTE.fmc400 has a very good reputation on FTE.fmc400 has a very good reputation on FTE.
When one plug is much, much dirtier than any of the other ones, it often indicates that cylinder is not firing. I'd check underneath your distributor cap and check the wire; if nothing shows up there you should do a leakdown test on that cylinder. You may find a burnt valve.
  #8 (permalink)
Old 05-21-2008, 02:32 PM
a burnt valve huh..that could suck...my dad told me maybe i need to adjust the carb a little and my friend is bringing a comprs test over later i left the plug out all night maybe i just flooded the cylinder im getting ready to go out and work on it thanx for the info.....
  #9 (permalink)
Old 05-22-2008, 12:55 PM
partsman01's Avatar
partsman01 is starting off with a positive reputation.
Do a wet and dry test when doing the compression check, to figure out if rings or valves are bad.
__________________
Proud owner of a Ford Truck.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
