Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-14-2007, 07:45 PM
mattmitch is starting off with a positive reputation.
NO Brake/Stop Lights???
Hi everyone,
I have an 82 Bronco. The brake/stop lights do not come on. I have checked the bulbs they appear fine, as my directionals work and the running lights work too, so both elements light up. I have checked the break/stop light switch located above the brake pedal and it receives power, and when brake pedal is depressed the switch does its job and allows current to pass through.
BUT NO BRAKE/STOP LIGHTS?
Now I'm getting confused because my HAYNES Bronco repair manual, electrical wiring diagram tells me that the stop light and the directional light share the same wire (lt grn-org), and originates in the stearing column at the horn,cruise,directional & hazard switch.
OK am i overlooking the obvious?
Is there some relay or sensor that is not detailed in the HAYNES manual that distiguishes the differance between a stop signal and a directional signal in this shared wire?
Please Advise.
Thanks Matt
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-14-2007, 09:30 PM
385seriesHemi is gaining momentum as a positive member of FTE.
Check the grounds
__________________
Jim "Iron Giant" Fahlin ~ A high performance car is like a guitar, you have to tune it to achieve your best operation and pull ahead of the competition.
  #3 (permalink)
Old 07-14-2007, 09:56 PM
Thanks,
I will check grounds once again tomorrow, As I have checked lots of them.
Matt
  #4 (permalink)
Old 07-17-2007, 01:51 PM
If its not a ground you will probably be chasing a short in the system.
__________________
  #5 (permalink)
Old 07-17-2007, 08:38 PM
2000Ford2000's Avatar
2000Ford2000 is starting off with a positive reputation.
If he has a short, it would blow the fuse. He must have a 'long' or something open.
I've heard of problems with the turn signal switch internally causing problems like this. If the manual is correct, you should be able to see that wire feed to the turn signal switch and check for 12 volt there. Remove the steering column housing to see it. If you have 12 v there, and your turn signals work, then the problem is in the switch assy. Is your hazard lights on the column too? If so check to see if the hazards work. Again, that's if the manual is right. It probably is but I've seen differences in the Haynes manual to actual with my 89 van.
__________________
2000 E-150 Jayco Conversion (5.4)
1989 E-150 Conversion (5.0)
-previous Fords
1989 E-150 Trans-Aire (5.0)
1988 E-350 26' Jayco RV (7.5)
B.C. (Before Children)
1991 Escort (1.9)
1982 Capri (2.3)
1971 Pinto (2.0)
  #6 (permalink)
Old 07-18-2007, 09:25 AM
Thanks for all the tips thus far,
I do not have Hazards to the rear lights but I do have Hazards to the front lights. I have ordered a new turn/hazard switch assembly and should be in today I will install that, and with my fingers crossed, hope to get this truck on the road again.
Again Thanks for all the help and I'll let you know if it was that switch assembly in the column.
Matt
  #7 (permalink)
Old 07-18-2007, 08:11 PM
That's probably the problem. I'm pretty sure it was on here that I've read about that problem before, several years ago.
__________________
-previous Fords
1991 Escort (1.9)
1982 Capri (2.3)
1971 Pinto (2.0)
  #8 (permalink)
Old 07-19-2007, 04:25 PM
Part still not in yet, sorry to keep up the suspence! I'll keep you posted
Matt
  #9 (permalink)
Old 07-19-2007, 05:51 PM
PARTS JUST ARRIVED-----INSTALLED-----PROBLEM SOLVED-----KEEP ON TRUCK'N
Thank You Guys
Matt
  #10 (permalink)
Old 07-20-2007, 05:13 PM
Cool!!!
__________________
-previous Fords
1991 Escort (1.9)
1982 Capri (2.3)
1971 Pinto (2.0)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
