Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-14-2007, 06:56 PM
390Highboy is starting off with a positive reputation.
Unhappy steering woes
I am having an awful time with the steering on my 93 f150. It steers hard and the steering wheel doesn't return on its own. If I am driving down the highway, the wheel basically stays wherever I put it, which isn't so bad on a straight stretch but scary on corners. I already tried adjusting the steering box, but no matter where I put the adjuster it didn't seem to make any difference. I've been noticing it getting stiff for quite a while, but it suddenly got really stiff about three days ago when we had an exceptionally hot day with temperatures around 100 F. I'm not sure if the heat really affected it or if it was just a coincidence. If anyone could give me some advice or share their experiences, I would appreciate it.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-15-2007, 09:13 AM
stuart1 is gaining momentum as a positive member of FTE.
Grease guns can make a big improvement.
__________________
Wrench twister since 1957.
Journeyman since 1964.
Transmission builder since 1964.
  #3 (permalink)
Old 07-15-2007, 10:03 PM
Tried that. This truck receives oil change and lube every 5000 miles. I'm going to take it to the nearest Ford dealer next week and see what they come up with. I'm dreading the bill I get later though.
  #4 (permalink)
Old 07-16-2007, 03:21 PM
krewat's Avatar
krewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud of
You have power steering?
Does it make any noise when steering?
Returning to center, that's alignment or stiffness in the components. SOMETIMES it might be a power steering fault, but usually it's weak and/or wanders or pulls to one side.
Stiff, well, something's wrong
Is it 4x4? Are the front axle u-joints good?
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Volant CAI, eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #5 (permalink)
Old 07-16-2007, 03:57 PM
merlynr is starting off with a positive reputation.
You have twin I beam right? Could be one of the kingpins is seizing up as I had that on a 78 one time. One of the grease fittings wouldn't take grease correctly. I took the tie rod off the suspect wheel and could barely turn the wheel side to side with it up on jacks.
__________________
97 F250 4X4 7.5
71 F350 dump 360
99 Explr XLS 4.0
05 Mustang GT 5 sp
73 Mustang cpe
71 Mustang cpe
65 Mustang fastback
  #6 (permalink)
Old 07-17-2007, 10:26 PM
Yes, it does have power steering; and it does have twin I-beam. It is 4x4 and the front u-joints appear to be good. The steering has simply become so tight that it will not return to center. It does wander a little, which could be alignment. The only noise I hear is a clunk when the steering wheel is rocked back and forth with the engine off. It sounds as if it is coming from the steering column itself. I have made an appointment at the local Ford dealer to have it checked out tomorrow. I'll post with the results.
  #7 (permalink)
Old 07-17-2007, 11:38 PM
wreckit72's Avatar
wreckit72 is starting off with a positive reputation.
I hope you get it figured out. I got mine figured out from the answers to your question in the 87 to 96 forum. I locked the hubs on mine today and the steering was binding worse and the left axle was clunking.
__________________
2008 F-450 Lariat 6.4L PSD CC DRW 4x4 4.30LS
2007 Ford Fusion V-6 AWD
  #8 (permalink)
Old 07-21-2007, 01:15 AM
The Ford dealer fixed my truck. They put a new steering box in it and aligned the front end. It drives much better. They socked me $630 though!
  #9 (permalink)
Old 07-21-2007, 01:35 AM
wreckit72's Avatar
Glad to hear that you got your truck fixed.
__________________
  #10 (permalink)
Old 07-22-2007, 07:49 AM
2000Ford2000's Avatar
2000Ford2000 is starting off with a positive reputation.
That's what junkyards are for. My first 89 E-150 lost it's steering box. $70 at the junk yard, exchanged the pitman, bolted it in, and off it went.
__________________
2000 E-150 Jayco Conversion (5.4)
1989 E-150 Conversion (5.0)
-previous Fords
1989 E-150 Trans-Aire (5.0)
1988 E-350 26' Jayco RV (7.5)
B.C. (Before Children)
1991 Escort (1.9)
1982 Capri (2.3)
1971 Pinto (2.0)
  #11 (permalink)
Old 07-22-2007, 09:28 PM
Well, normally I would have went to the junkyard but I didn't know what the trouble was, and I needed the truck. Oh well, next time I'll know better.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
