1965 wiring diagram - Ford Truck Enthusiasts Forums
1965 wiring diagram
Old 07-14-2007, 08:16 AM
EricJ EricJ is offline
EricJ is gaining momentum as a positive member of FTE.EricJ is gaining momentum as a positive member of FTE.
1965 wiring diagram
Anyone have a decent wiring diagram for the 65, the one I have is a POS.
Old 07-14-2007, 09:07 AM
ddavidv's Avatar
ddavidv ddavidv is offline
ddavidv is gaining momentum as a positive member of FTE.
If it's the multi-page one that has the big trucks included that they repro, I think that's all there is.
Old 07-16-2007, 01:42 PM
daggerNC daggerNC is offline
daggerNC is starting off with a positive reputation.
Eric - I have the '66 wiring diagram "booklet". Can't say for sure if identical to the '65, but tell me what model and diagram view you need and I can email you something.
daggerNC
Old 07-18-2007, 05:45 PM
Quote:
daggerNC
Thank you sir, you've got mail. :-)
Old 07-19-2007, 11:33 PM
Eric - I didn't receive any mail yet? Try sending me a PM first....
Old 08-07-2007, 12:47 PM
trucksforlife29 trucksforlife29 is offline
trucksforlife29 is starting off with a positive reputation.
Hi I am new here as well and I am in need of a good wiring diagram for my truck also I have a 66 F100 short bed and I would love to get a diagram for it the wiring is crap on my truck too and I have been unable to find one on the net for free I figure if any of you might possibly have one that you could share that would be great if you could reply I will send you my email address. Thanks
Old 08-14-2007, 07:03 PM
rbs_bowties rbs_bowties is offline
rbs_bowties is starting off with a positive reputation.
Wiring Diagram for 1966 F100
Any chance that I could get a copy of the wiring diagrams / schemtaics for the 1966 F100 long box?
I am looking to re-wire the truck but have been un-successful in finding a company making a new harness for the truck. Both Painless and Ron Francis start with the 1967 F100, so I would really appreciate a diagram to work from when creating my own.
Thanks,
Rob
daggerNC
Old 08-14-2007, 07:44 PM
daveengelson daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Have a 65 F100 and have not found anyone who repro's the dash harness. Disassembled the harness and replaced bad wires and connectors, then reassembled using wire wrap harness tape, not the sticky stuff. Came out better than expected, this was several years ago, no dash fires as yet. Been couple years since last checked, but Mr. Mustang, Inc., use to repro's the Ford F100 truck wiring harness for 64-67, have to call them, no online listing for their harnesses. Pleased with quality, actually purchased an extra set for another 65. Same wire color codes and connectors, matter of unplugging the old and plug in the new. If intend adding some trick electrical circuits then imagine aftermarket may be way to go, am basically lazy and wanted to keep it simple.
dave
Old 08-14-2007, 10:20 PM
ol yeller ol yeller is offline
ol yeller is starting off with a positive reputation.
I've got a wiring book for the 66. If possible I will scan it and send anyone who needs info. Also just pulled off awiring harness that is the headlights and horn. Just what's under the hood. Got a classified posted.
Old 04-12-2009, 07:05 PM
tommyrs33 tommyrs33 is offline
tommyrs33 is starting off with a positive reputation.
Can anyone send me this diagram? I swapped a 460 into my 65 and have one heck of a wiring issue. I traced power from the bettery across the front of the truck, into the voltage regulator, into the cab, then into the steering column and that's it. Everything worked when I pulled the truck in to the garage. I'm lost. I have no ignition, headlights, anything. I don't know enough about electrical. It has to be something simple. On the otherside of things the battery goes to the starter solenoid and that's all. No power comes out of any of the terminals. Shouldn't one of these be hot? I mean I can do the old cross the solenoid out and it turns over. I can make the truck run by running a jumper to the distributor. Just cannot figure out why I have no power in the cab anymore. I have redone all my grounds. Even ran extra grounds from the cab to the frame and the front clip to the frame. Sorry to bring up an old post but I have searched and found nothing and I'm ready to just put the things up for sale and take whatever I can get. Please help. Thanks
Old 04-12-2009, 08:35 PM
F250GH F250GH is offline
F250GH is starting off with a positive reputation.
Quote:
At the main engine harness plug under the hood, check for voltage at the top right connector, (Black w/Yellow Stripe). This is the power feed from battery to ignition switch. Do you have the engine to firewall ground strap connected? The best way to do this is with a digital voltmeter. Of course your headlights are wired to the other harness which runs through the fuse box, so checking power at the fuse box would be a good starting point for troubleshooting lights, horn, and accessory problems.
Try looking at the connectors on both main harness plugs under the hood on the firewall. These are always corroded, or may just not be making a good connection.
Ken
Old 04-13-2009, 01:04 PM
kwlowe kwlowe is offline
kwlowe is starting off with a positive reputation.
ol yeller,
would love to have wiring diagram for my 1965 f100. how do we connect. please excuse my ignorance (new user) in forums
Old 04-13-2009, 06:20 PM
You can buy them on Ebay or any parts dealer for $8 - $10. They are limited in details though,(not as detailed as say the Mustang wiring diagrams).
Ken
Old 04-13-2009, 06:40 PM
63beater 63beater is offline
63beater is starting off with a positive reputation.
This is my first day here and believe it or not here is what you are looking for.
Copy and paste this to your browser.
1964 F100 - F750 Wiring Diagrams - The Old Car Manual Project
Old 04-13-2009, 06:42 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
I do have the cats meow for 65 truck wiring diagrams...name your series...Ive got em all..from E series all the way to T series...email me with your needs...the book you always see everywhere I have and its sorta kinda close to the actual trucks wiring...but Ive got parts harnesses Ive compared the pamphlet to as well as my book...a FoMoCo published book btw...the Ford book its dead nuts on correct...
- cs65
Wiring Diagram b_swift72 Excursion - King of SUVs 58 12-03-2015 09:02 PM
trailer wiring harness diagram Trent Racer 1987 - 1996 F150 & Larger F-Series Trucks 5 08-21-2015 06:35 PM
Wiring Diagram kountzecobra 1987 - 1996 F150 & Larger F-Series Trucks 15 08-08-2015 09:40 PM
Wiring Diagram afrank 1997 - 2003 F150 0 03-31-2015 06:03 PM
Wiring diagram needed Shwan_89HD Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 08-08-2014 10:47 PM
Tags
1965, 1966, 65, 66, alternator, cab, codes, color, column, custom, diagram, f100, ford, pickup, steering, truck, wireing, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
