1965 wiring diagram - Page 2 - Ford Truck Enthusiasts Forums
1965 wiring diagram
Old 04-13-2009, 06:47 PM
doc66 doc66 is offline
doc66 is starting off with a positive reputation.
Quote:
Originally Posted by daggerNC View Post
Eric - I have the '66 wiring diagram "booklet". Can't say for sure if identical to the '65, but tell me what model and diagram view you need and I can email you something.
daggerNC
Hey daggerNC,
doc66 here. I downloaded a wiring diagram for my 66, and it seems to make sense. I'm wondering if you might have something different, though. Would you mind emailing me a copy of what you have? I'd be glad to send you what I've got in return. Same for anyone else interested.
Old 07-11-2010, 11:04 PM
DbleJ2010 DbleJ2010 is offline
DbleJ2010 is starting off with a positive reputation.
Quote:
Originally Posted by camperspecial65 View Post
I do have the cats meow for 65 truck wiring diagrams...name your series...Ive got em all..from E series all the way to T series...email me with your needs...the book you always see everywhere I have and its sorta kinda close to the actual trucks wiring...but Ive got parts harnesses Ive compared the pamphlet to as well as my book...a FoMoCo published book btw...the Ford book its dead nuts on correct...
- cs65
i was wondering if you could email a dash wiring diagram for my 65 f-100?
Old 01-18-2011, 05:38 PM
tidalwave tidalwave is offline
tidalwave is starting off with a positive reputation.
Another kinda new user with multiple electrical questions. Truck is 65 f100 with 240 6. Purchased it, drove about 50 miles home, pulled to curb to move another vehicle and thus gain access to back yard, went back to truck, wouldn't start. Once I got in the backyard, started first by replacing the battery-no luck. I currently have no power at all when I turn key. Worked on problem today and installed a new coil-still nothing. Am extremely inexpierenced with electrical problem solving. More infor- the engine compartment has been very jury rigged-wires coming from cab into engine bay but not connected to anything etc. Please help.
Old 01-18-2011, 07:05 PM
EricJ EricJ is offline
EricJ is gaining momentum as a positive member of FTE.EricJ is gaining momentum as a positive member of FTE.
Quote:
I'm guessing if you replaced the coil, you don't have a clue, so lets start slow.
clean and tighten both the battery cables, the "+" is on the solinoid, and the "-" should be connected to the engine block somewhere.
Now there are 2 small wires and 2 large wires on teh solinoid. One of the large ones is the one you connected from battery"+". the other goes to the post on the starter, make sure that one is clean and tight on both ends.
now you need to have some-one turn the key while you check the 2 small wires on teh solinoid, one is marked "I" for ignition and the other is marked"S" for start. when you turn the key to the start position the "S" wire should become live, the solinoid should make a loud click , the wire to the starter shoulld become live and the starter should crank.
see if that helps.
Old 01-19-2011, 09:15 AM
huckdeuceman's Avatar
huckdeuceman huckdeuceman is offline
huckdeuceman is starting off with a positive reputation.
I have a 65' Thanks for the Diagram 63 beater!!..it looks just like mine!
Old 02-03-2011, 08:03 PM
lilgolfer's Avatar
lilgolfer lilgolfer is offline
lilgolfer is starting off with a positive reputation.
65 wiring
any chance i could get a copy of that too?
Old 02-05-2011, 10:00 AM
mba8820 mba8820 is offline
mba8820 is starting off with a positive reputation.
I am also in need of a starter circuit wiring diagram. I have a 65 F250 original 4x4 trk with 240 6 cyl. What I really need is info relative to the resistor block mounted on inner fender panel that is no longer there.
Old 02-09-2011, 07:47 PM
smkf100 smkf100 is offline
smkf100 is starting off with a positive reputation.
Could you also email me a copy. Thanks
Old 02-16-2011, 11:24 PM
Harleyyoungster Harleyyoungster is offline
Harleyyoungster is starting off with a positive reputation.
I could sure use any wiring diagrams for 1966.
I have an F 100 and an F 500
Thanks in advance
Old 02-16-2011, 11:57 PM
Jetcopterpilot's Avatar
Jetcopterpilot Jetcopterpilot is offline
Jetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputation
Quote:
Originally Posted by 63beater View Post
This is my first day here and believe it or not here is what you are looking for.
Copy and paste this to your browser.
1964 F100 - F750 Wiring Diagrams - The Old Car Manual Project
Thanks I loaded it into my favorites, and will print it out and save it.. it is dead on for my truck!
Old 03-02-2011, 02:49 PM
ThinkItBuildIt ThinkItBuildIt is offline
ThinkItBuildIt is starting off with a positive reputation.
Would somebody send me a copy of the wiring diagram for the 65 f100? email at whitneyel3@gmail.com Please please please and thank you thank you thank you
Old 06-07-2011, 07:43 PM
bruce.charles bruce.charles is offline
bruce.charles is starting off with a positive reputation.
One more time?
sorry to sound like a broken record but if someone wouldn't mind emailing me the wiring diagrams for a 65 that would be amazing. For no apparent reason both my headlights and my dash lights have stopped working, parking lights still work though and my electrical abilities aren't the best. Thanks in advance. bruce.charles@rocketmail.com
This site is a god send and I would be lost without you guys!
  #28
Old 06-07-2011, 08:38 PM
daveengelson daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Posting couple circuits, sorry, had several pic's of the other circuits in my photo-bucket storage site but apparently they are floating about in cyber-space, may have exeeded allowable photo's in storage and have to delete a few to retreive the wiring diag. Anyhow, 1 of the links shows the headlight circuit, these darn electrical gremlins are a pain in the backside, majority of the time I find the problem's due to a poor ground. Perhaps another member will be able to provide add. circuits, purchased the wiring manual from Jim Osborns Reproductions for $7, well worth it.
http://i300.photobucket.com/albums/n...reDiagP5-1.jpg
http://i300.photobucket.com/albums/n...WireDiagP7.jpg
  #29
Old 06-07-2011, 09:38 PM
Thanks a bunch. I was planning on ordering a set but wanted to get on the repair sooner than later. Thanks again, it's gremlin hunting I go.
cheers
Charles
  #30
Old 06-07-2011, 10:01 PM
ffflash480 ffflash480 is offline
ffflash480 is starting off with a positive reputation.
Just a question, got a ez wiring harness for my '66 f100. has anyone installed one and anything i need to look out for?
Wiring Diagram b_swift72 Excursion - King of SUVs 58 12-03-2015 09:02 PM
trailer wiring harness diagram Trent Racer 1987 - 1996 F150 & Larger F-Series Trucks 5 08-21-2015 06:35 PM
Wiring Diagram kountzecobra 1987 - 1996 F150 & Larger F-Series Trucks 15 08-08-2015 09:40 PM
Wiring Diagram afrank 1997 - 2003 F150 0 03-31-2015 06:03 PM
Wiring diagram airborne0130 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 02-25-2015 05:53 PM
Tags
1965, 1966, 65, 66, alternator, cab, codes, color, column, custom, diagram, f100, ford, pickup, steering, truck, wireing, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
